Old 10-15-2007, 02:42 AM
ircswh ircswh is offline
Default Changing Tempo of song when using audio samples?
Ive tried to figured this out on my own. But nothing seems to works. Im using samples and everything is synced up perfectly BUT I wont to speed up this track. But everytime I try to do this all the midi tracks speed but the audio sample stay the same. I used the sample / tick button but doesnt seem to work. How do you speed up the entire song including the samplles/audio.?
Old 10-15-2007, 08:00 AM
msg6794 msg6794 is offline
Default Re: Changing Tempo of song when using audio samples?
you'll have to use something like the time-compression/expansion plugin to compress/expand your audio samples to the new bpm. changing the tempo only affects midi stuff, you have to change the audio separately. if you have serato pitch 'n time, that sounds Really good, though the default protools ones are decent most of the time.
003 Rack | Dell Studio XPS 8700 (Core i7 4790, 16GB RAM) | Windows 10 64-bit / PT 12.6
Old 10-15-2007, 08:01 AM
spkguitar's Avatar
Unless the audio samples you are using are REX or ACID files (or you imported them incorrectly), then tick based tracks will do you no good. You will have to time expand the audio (using the TCE tool) to the grid after changing the tempo. With the current version of Pro Tools, this can not only get pretty tedious, but can sometimes have negative results when it comes to the audio quality. (You really need to know what you're doing and why when time expanding audio, and you need to be using a quality TCE tool).
The new version of Pro Tools (7.4) that will be released next month includes the new "elastic audio" feature that will make the task you are attempting much, much easier to do within Pro Tools.
Old 10-15-2007, 09:23 AM
This is so odd to me. It seem like something that would have been made easier to do a loooooooooooooong time ago. Oh Well
So for now I can first import the audio in to SOny Acid and then in to Pro tools And I be able to manipulate the tempo normally?
Changing tempo in a song help! WilliamBolt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-16-2010 01:57 PM
Changing Song Tempo SoulRiderLeo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-30-2008 04:18 PM
Problem with Elastic Audio when changing the tempo of song fenderjose 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-25-2008 07:02 PM
changing the tempo of a song dwayne00 Tips & Tricks 3 04-25-2008 10:45 AM
Changing Tempo Mid-Song Jason Kardong 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-20-2007 12:54 PM
