Old 06-23-2005, 03:43 PM
whtrabit whtrabit is offline
Default Rupert Neve Is Back!
http://www.rupertneve.com/
And this sounds interesting:
PorticoTM 5042 Two-Channel "True Tape" Emulation and Line Driver
Two-channel “True Tape” Emulation. An actual tape drive circuit is used to drive a tiny magnetic circuit and fed to a replay loop and actual replay preamp. “Record” and “Replay” levels are counter-ganged to keep overall gain approximately constant that only varies, as a tape would, with saturation level. The frequency response is tailored to that of an actual tape recorder. The result is a remarkable simulation of true tape sound, providing the nostalgic rounding and compression that offsets the harshness of poor digital recorders. Use with care! The dynamic range of a tape recorder was a lot less than that of the high resolution Portico Line circuit in which it is nesting!
Each of the two 5042 channels is equipped with the following:
- Input Level control.
- Tape Saturation Level control.
- 10 segment Meter reading input or saturation level.
- “7.5/15 IPS” switch
- Independent Bypass per channel
jimmy
15" Macbook Pro R 2.6 i7 Quad/16GB RAM/OS X 10.10.5
27" iMac 2.8 i7 Quad/16GB RAM/OS X 10.10.5
Studio One 3/Reason 8/Live 9/Logic Pro 9/Main Stage 3
Rupert Neve Designs Portico 5012 - FA (two available) jamiecer Buy & Sell 1 03-18-2014 07:14 PM
Has anyone tried the new Rupert Neve Portamento? colnago 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-08-2005 09:14 AM
OT: Has Anyone Tried the Rupert Neve Portico Pre? MissHiss Pro Tools TDM Systems (Mac) 26 09-26-2005 07:38 PM
Rupert Neve Stone Knife 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 14 05-08-2002 03:10 PM
Rupert Neve Interview Xendo Tips & Tricks 17 05-05-2002 08:40 AM
