Old 05-12-2022, 08:01 AM
cjbaumakl cjbaumakl is offline
Default Soundminer Issue with ProTools v2022.4.0
Experiencing an annoying bug with ProTool 2022.4.0 when using Soundminer (version 5.0v764 Pro). When I try to "Spot to DAW" from Soundminer, it properly transfers my SFX / audio file to my ProTools timeline, BUT it will not move my ProTools edit window to front (as it used to with previous PT versions). Instead, the SoundMiner window stays in the foreground and I have to manually switch back to ProTools app. I spent some time troubleshooting with SoundMiner support (who are terrific), and they now surmise this is a ProTools issue, because when you do a test with Quicktime (and set quicktime as your new DAW app), it works perfectly. Anybody else experience this or find a fix? I have also checked my "Accessibility" and "Automation" access in System Prefs, and they all seem correct for Soundminer.
Thanks!
ProTools 2022.4.0
iMac 27", 2020. 3.6GHz 10-Core Intel Core i9
Memory 64gb 2667 MHz DDR4
macOS Big Sur v11.6.5
Old 05-12-2022, 12:41 PM
audiolex1 audiolex1 is offline
Default Re: Soundminer Issue with ProTools v2022.4.0
Thanks!
ProTools 2022.4.0
You have switch to target app checked? Maybe try unchecking and rechecking.
Mac Pro 5,1. 3.46 12 core, 128 gigs ram, 580 GPU flashed Apple EMI, 3 monitors
PT Ult 2023.6, OSX 10.14.6, 3 card PCI-e expansion with 3.2 USB Sonnet card.
OCTO 8 card, Apollo 8 Quad, UAD quad satellite FW.
Almost every plugin
Old 05-12-2022, 01:05 PM
audiobob's Avatar
audiobob audiobob is offline
Thanks!
ProTools 2022.4.0
Works as it should here but on SM V5 5.0v716 and Monterey 12.3.1 .
Old 05-12-2022, 01:25 PM
BScout BScout is offline
Works as it should here:
SM v5.0v768 Pro
(you also seem back a version)
wondering if this a macOS issue
Pro Tools v2022.4 Now Available Avid Technical Alerts 0 04-26-2022 08:47 AM
Rewire/ soundminer issue postprosound Post - Surround - Video 2 09-27-2011 11:08 PM
Issue with soundminer villagesound Pro Tools TDM Systems (Mac) 2 11-09-2009 01:26 PM
7.4 an Soundminer issue gugu Post - Surround - Video 18 11-19-2007 02:47 PM
Soundminer 3.2LE & Protools 7 argot Post - Surround - Video 7 07-24-2006 07:38 AM
