Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 04-27-2021, 05:26 PM
ausitndj ausitndj is offline
Default Trouble setting up microphone on Pro Tools using Windows
I have an AudioTechnica 2020 USB microphone as well as the ASIO4ALL program needed to use it on Windows Pro Tools. I am having trouble with the I/O setup, or more simply the output. My output reads Not Connected 1-2, my microphone and audio driver are both active on the ASIO4ALL offline settings(hardware settings). It seems as though when my microphone is active the output does not work, or it immediately stops the speakers from working. I am just using computer speakers.
I greatly appreciate any help, tips, or advice.
Old 04-28-2021, 10:10 AM
The Weed's Avatar
The Weed The Weed is online now
Default Re: Trouble setting up microphone on Pro Tools using Windows
So you want to use your microphone and hear it through your computer speakers? Not a good idea, you'll wind up with howling feedback from the loop that will create. You need to use headphones and mute the speakers.
Pro Tools really needs an interface with proper ASIO drivers, not ASIO4ALL, which is a "bandaid" that allows your onboard soundcard or USB microphone to seem like it has an ASIO driver.
If you don't really need Pro Tools, I would suggest looking at single track DAWs like Audacity or OcenAudio, or a multi-track like Reaper or Harrison Mixbus. Those and others are not (nearly) as finicky, especially on Windows, as Pro Tools is. Avid is DIVA spelled backward.
As always, YMMV.
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Trouble setting up Buses on Pro Tools 12 McFuzz94 Pro Tools 2018 9 04-14-2018 05:28 PM
Trouble setting up Pro Tools DriiDono Pro Tools 12 5 11-09-2015 12:52 AM
Confusion when it comes to setting up a microphone Tastypants Getting Started 3 12-06-2013 07:14 PM
Setting Up The Microphone leecappella Pro Tools SE and Essential (Win) 1 10-24-2010 12:09 AM
Setting up microphone on DIGI001 karldrei 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 02-12-2004 07:05 PM
