Shortcut Problem with with switching Mix/Edit Page
Hi Everyone,
I m new on windows 10 and i have two problems. First, the shortcut to toggle between windows (ctrl =) doesn t work. All the other short cut are alright but not this one. Second, i can t scroll left right with the pad on PT 12. It does work on all the others app. Can somebody help me please ? I have a mix session starting in 1 hour huhu Cheers |
Re: Shortcut Problem with with switching Mix/Edit Page
Not a clue as it works fine here. Is there some keyboard utility being used to re-program any keys? Second, i can t scroll left right with the pad on PT 12. Not sure what "the pad" is. If you hold SHIFT, the vertical scrolling should switch to horizontal scrolling. If you are trying work PT on a laptop touchpad, I highly recommend adding a mouse or trackball. I'll do some recording with a track pad(and lots of moaning), but when it comes to editing, a touchpad leaves a lot to be desired
Thanks for the answer.
Just so you know, it was because it doesn t work with the swiss QWERTZ keyboard settings. i changed it to UK and now it s fine. cheers |
Strange Folder Shortcut problem in Edit Window | grameswan | Pro Tools 2020 | 2 | 11-08-2023 07:15 PM |
Strange Folder Shortcut problem in Edit Window | joeshepard | Pro Tools 2020 | 0 | 06-04-2020 01:30 AM |
Feat. Req: Stay on same page when switching track | Frank Kruse | Artist Series | 12 | 01-17-2012 12:13 PM |
MIDI edit page.... Edit Window Scrolling ... Page | Norm Mix | MIDI | 1 | 07-06-2009 07:31 PM |
PT8 switching between mixer/edit one-key-shortcut | erans | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 03-30-2009 03:14 PM |
