Old 01-28-2008, 07:18 AM
perh perh is offline
Default MIDI Realtime Properties(Transpose) forgotten on reload...
Hello Digi..
MIDI Realtime properties on transpose on a channel is not remembered when reloading a session(and also on PT reload).
This only goes for incoming MIDI and not for the playback.
Everytime I want to work on a channel with realtime transposition I have to Disable and Re-enable "TRN" button in order for
the transposed MIDI to come through...
The problem has been present since 7.3... ( I just forgot to write about it, since it seems like a small issue for me too )
- and is present with all INST Plugs(NI/Reason/Arturia/DIGI)
Per H.
PTLE7.4cs2
Powerbook 15" HR 1.67
Mac OS X 10.4.11
Old 04-23-2008, 10:24 AM
DigiTechSupt's Avatar
Default Re: MIDI Realtime Properties(Transpose) forgotten on reload...
We just tested this and cannot reproduce the problem.
Have you tried trashing preferences? Also you can try trashing MIDI prefs:
Go to MacHD>Users>your account>Library>Preferences>By Host and trash 'com.apple.midi.a bunch of numbers and letters.plist'.
Go to MacHD>Users>your account>Library>Preferences and trash 'com.apple.audio.audiomidisetup.plist'.
Empty the trash and restart, then see if everything is working.
Avid Audio Tech Support
Support FAQ
Old 04-23-2008, 07:22 PM
Everytime I want to work on a channel with realtime transposition I have to Disable and Re-enable "TRN" button in order for the transposed MIDI to come through
Ummm... I second this. And not only confined to Transposition but to Duration also. Though, I have only noticed this with Track-based RTP.
Windows.
filosofem
Aaron Mulqueen - 001 HD Native
Old 04-26-2008, 03:22 PM
DTS, another issue with track-based RTP is importing session data with track-based RTP Quantize enabled. The MIDI data doesn't display and compacts all data to the first beat of the bar. Disabling Quantize displays the data but in turn the data is then un-quantized. Repeating the process results in the data failing to display.
I've created a screencast of this but are currently having difficulties uploading to Screencast.com (issue their end) just to varify.
Windows XP
Pro Tools 7.4 cs4
filosofem
Old 05-06-2008, 08:06 PM
DTS, finally got this video away. Link
filosofem
Old 05-21-2008, 10:30 AM
I'm just dropping in to let you know that we were able to reproduce this and log it for a fix.
Support FAQ
Old 05-25-2008, 10:03 PM
Hey thanks DTS!
filosofem
MIDI bug - Transpose Firechild macOS 6 03-27-2020 07:42 AM
midi realtime properties Prefs? mickblah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-26-2008 05:06 PM
Transpose incoming midi justmull1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-18-2006 09:57 PM
Midi transpose bug?? Stig Eliassen Pro Tools TDM Systems (Mac) 4 06-07-2005 09:31 AM
Midi transpose pre record delta MIDI 0 11-04-2003 08:23 AM
