Old 09-03-2004, 01:42 PM
Zenunave Zenunave is offline
Default MIDI quantize
Hello, I'm trying to quantize a Mozart piano sonata (K330) so that each note ends at the exact start of the following note. Is there a trick to doing this or do I have to systematically go through the different parts of the sonata and quantize individual groups of notes or even single notes at a time?
Old 09-03-2004, 02:57 PM
myfm myfm is offline
Default Re: MIDI quantize
If you want to quantize on a dime, in the quantize window 'include within' and 'strength' should be 100% and the others zero. Make sure you have attacks and releases enabled. Remember if any note is 50% or more to being off, it will be quantized to the nearest 8th or 16th note depending on your setting, and you'll have to go through and manually fix those notes.
ProTools 8 MIDI quantize? Stixxs MIDI 3 12-23-2009 02:52 AM
MIDI Quantize barlevy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 09-04-2009 02:09 AM
Midi doesn't quantize before bar 1 sammyfarr Pro Tools TDM Systems (Mac) 1 06-05-2007 01:01 AM
PT 6.1 bug in Midi quantize? Jonathan Gordon Pro Tools TDM Systems (Mac) 0 04-08-2005 09:08 AM
Problems with MIDI Quantize! rme_uk Pro Tools TDM Systems (Mac) 4 07-24-2001 06:05 AM
