Old 11-07-2009, 11:26 AM
goaler111 goaler111 is offline
Default 002 not clocking to correct sample rate for itunes and quicktime
I have a Black Lion Audio 002. When I first got it I was running PT 8.0 and had no problems with it. As soon as I installed 8.0.1 the unit clocks to 48KHz for itunes, quicktime and anything else that is not in Pro Tools. It clocks perfectly to Pro Tools for whatever sample rate I am working with but ever since that update was installed it switches to 48KHz for everything but PT. There aren't any user adjustable setting in the DigiCore Audio manager that I can find that will solve the problem. The sound seems to be fine from itunes, like it doesnt sound too fast or slow but it just doesnt seem right to me. Someone help please. Thanks,
-Jon
Old 11-07-2009, 11:57 AM
BRH BRH is offline
Default Re: 002 not clocking to correct sample rate for itunes and quicktime
Have you checked your Audio Midi setup in Utilities folder?
Old 11-07-2009, 04:46 PM
Yea and under properties for the 002 in the Audio MIDI setup the sample rate input and output always reads 48KHz each time I open it even when I change them to 44.1KHz. Its like the settings in the audio midi setup keep defaulting to 48KHz and no matter what I select in there my interface keeps clocking to 48KHz for everything but PT. More help please. Thanks,
-Jon
Old 11-07-2009, 05:30 PM
djkiller djkiller is offline
my digi002 just started clocking the same when i use itunes but it use to go to 96khz. i'm kinda in the same boat...i haven't really troubleshot it yet but i do remember for some reason when i had the issue before it coencided to whatever my last session was set to in logic9 for some reason and whatever the coreaudio was clocked through by it. i guess i'll try the preferences also :P
Old 11-07-2009, 08:40 PM
Brian21310 Brian21310 is offline
its a bug. the annoying work around is to open digi core audio manager, click HW setup, and change sample prior to opening itunes, logic..etc u have to do it before opening itunes, logic ever time
Old 11-07-2009, 09:11 PM
Soliton Soliton is offline
Thumbs down Re: 002 not clocking to correct sample rate for itunes and quicktime
goaler111...
I have the exact same problem. Trying to set it in Audio MIDI Setup does nothing. It just reverts back.
Pretty annoying.
Old 11-07-2009, 09:13 PM
dude i just tried the settings in the midi and audio and nothing. i was having the same issue. turns out i went into logic and set it at 96 and then exited and guess what... itunes works in 96 for me now. crazy! must be a glitch in core audio. thought this might help you a bit if you have other daws on you computer.
Old 11-08-2009, 08:36 AM
Well at least i'm not the only one. Digi please fix this in the next update, whenever that is, along with Delay Compensation for LE. I promise if you makes these fixes I will buy a digi plug-in or a toolkit or something. Thanks,
-Jon
Pro tools could not set your audio device to the correct sample rate innermusic Pro Tools 10 4 05-06-2012 09:25 PM
Digi002 + itunes = 48k sample rate??? DEXTERITY 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-30-2009 12:57 PM
iTunes 7.3.2 causes sample rate to change max cooper 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 09-04-2007 09:51 AM
Please Help! Sample Rate/Clocking = Slow Motion... Amo Audio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2005 04:48 AM
Correct ADAT sync mode and sample rate? Stenjy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-23-1999 11:48 AM
