Old 07-02-2008, 08:17 PM
cakes cakes is offline
Default McDSP ML4000 - does the full version work on LE?
Hi folks,
I'm looking into getting the McDSP ML4000. If you look at the bottom of the product page on the McDSP website, they have a table that lists the different purchase options. At first I thought you could only buy the limited version to use with PTLE, but under "HD Version" they list RTAS. Can I buy the HD version for my LE system and use the RTAS plugin with my 002?
Thanks,
cakes
Old 07-02-2008, 09:39 PM
dj_stick dj_stick is offline
Default Re: McDSP ML4000 - does the full version work on LE?
McDSP have 3 versions, HD, Native and LE
HD & Native are identical, except the HD Versions will run on TDM, Native are RTAS only
LE are cut-down versions
buy the Native version for your PTLE rig, as buying the HD version is a waste of money
Old 07-03-2008, 11:41 AM
dj_stick,
I'm trying to avoid dropping $1395 on the Native Bundle. The McDSP website says the HD version ($495) includes an RTAS plugin - can I use that on my 002?
Thanks,
cakes
Old 07-06-2008, 02:19 PM
antidogmatiq antidogmatiq is offline
Native means runs on your host cpu so in PT thats RTAS.If you buy HD, RTAS should work fine on 002. (However an mail to McDsp wont hurt )
But....
If you dont need the multiband part of ml4000 i recommend go LE pack.
You will get much more for your bucks.
I own this bundle (and 002) and i am really happy with it.
ML4000 is soooooo nice!
Old 07-07-2008, 01:17 AM
Sonic Nomad Sonic Nomad is offline
If you can get the the whole bundle - It's worth every cent.
Better yet get the demo and try it for yourself.
If you really only want a multi-band limiter and are open to trying something new then check Pro Audio DSP's new plug,DSM - Dynamic Spectrum Mapper
Pro Audio DSP is Paul Frindle's new company. Paul used to be with Sony where He was involved with the development of the Oxford stuff. (Oxford plugins are now called Sonnox)
Check it out.
Old 07-08-2008, 12:28 PM
So I talked to McDSP support, and the answer is yes. The HD version will work with PTLE.
They also happen to be having a sale on individual native plugs for $295, so I'm definitely going to be getting the ML4000!
cakes
Will Pro Tools 9 Full Version work with my Desktop PC - Full Sandra Report included ToddnTodd Windows 8 05-20-2011 02:16 AM
McDSP ML4000 vs Ozone? MetalDrmr 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-12-2008 08:20 AM
McDSP Channel-G and ML4000 out for Windows Native! jeff markham 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-20-2006 06:54 PM
McDSP ML4000 LE & Intel Support Bassturbator 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-26-2006 12:49 PM
McDSP ML4000 Mastering Limiter Dutchmuzik Pro Tools TDM Systems (Mac) 5 07-01-2006 01:34 AM
