Old 11-09-2009, 04:44 PM
jmeharry jmeharry is offline
Default Sustain pedal cuts out while recording. Can't figure it out.
ProTools suddenly started cuting out the sustain pedal while recording with my MIDI keyboard. I tried following the steps in this post with no luck:
http://duc.digidesign.com/showthread.php?t=252596
The sustain pedal randomly stops "sustaining" while recording. HOWEVER, when it's played back, the "cutting" out doesn't show up which means that the sustain data is being recorded, it just doesn't sound that way while recording is in progress.
Anybody have any ideas? This issue is driving me nuts! Oh, I should also say I tried upgrading to the latest version of ProTools (8.0.1) but that hasn't helped either.
Thanks!
Old 11-09-2009, 09:13 PM
Default Re: Sustain pedal cuts out while recording. Can't figure it out.
I figured it out! The "Merge MIDI" button was clicked on the transport window and for some reason that was causing it.
Problems with MIDI Sustain Pedal while recording ChrisSimon Pro Tools TDM Systems (Mac) 72 06-25-2014 10:30 AM
PT8, Sustain pedal, velocity problems while recording ChrisSimon MIDI 1 08-20-2009 05:23 PM
sustain cuts out while recording midi tromostheory 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-08-2007 05:29 PM
Piano sustain pedal in recording Help!! Zownd Tips & Tricks 9 04-05-2004 02:21 PM
Sustain Pedal in Midi recording in PT LE Arya44 Tips & Tricks 1 11-09-2003 11:25 PM
