Old 10-31-2019, 02:06 PM
TornadoTed TornadoTed is offline
Default Re: Drag and drop AAX sampler
Originally Posted by Jon_Atkinson View Post
Not out of the timeline it isn't unfortunately.
Also, it doesn't play spread across the keyboard, nor is it polyphonic (for a single sample)... Not sure if the OP was looking for that (or that's just my reading of his post, given that he mentioned sound design)
Battery is great, and as you say is drag and drop (from the finder), but if you're recording audio in the timeline and want to manipulate it and play back using a keyboard then it's not the right tool.
I do exactly what the OP is talking about, and use Ableton for this (Simpler is really great for this kind of sound design)
I've been round the houses trying everything.... I've used pretty much every soft sampler out there (except the new TAL one which I've heard is great by the way).... Even got a Yamaha A4000 to try, and often use my OP1 for similar....
Ableton and Simpler, ReWired into PT is where I'm currently at...
Such a shame that support for developing Structure fell by the wayside. It could have been great for this.
That's a really interesting solution. I did a tiny bit of research on Ableton rewired to Pro Tools when I was considering ditching Cubase but read that Ableton was 'crippled' when used as a Rewire slave and couldn't host VST's. I didn't consider that the inbuilt Simpler would work as I assumed that was a VST instrument.
Old 11-01-2019, 04:32 AM
Jon_Atkinson Jon_Atkinson is offline
Yeah... it's kind of semi-crippled...!
Depends on your exact workflow, but it might be worth a try...
Simpler has some really nice features, like warped playback, so if you have a sample with (for instance) a tremolo running, you can play a chord and the trem will happen at the same speed for each held note (so the trems play in time). That's also easily disabled too if you want.
3rd party plugins won't work, but the built-in Ableton ones do, and they're actually really good.
Mac Pro 2019 3.5GHz 8 Core 48GB RAM
OS 13.6.3
Protools Studio 2023.12
Antelope Orion 32, Vienna Ensemble Pro 5,
UAD Quad PCIe
Old 11-01-2019, 04:44 AM
Actually a sample in a Battery 4 cell CAN play across the keyboard changing pitch as you go. You have to enable key follow in Battery. And you can limit the key range it plays over as well.
Jack
QAPLA!
Old 11-01-2019, 04:56 AM
ubxf ubxf is offline
Maybe the new Soundminer
Old 11-02-2019, 03:29 AM
Can you drag audio from the Pro Tools edit window or clip list and drop it straight into Ableton?
  #16
Old 11-02-2019, 11:40 AM
DAWgEAR's Avatar
DAWgEAR DAWgEAR is offline
What I do is select and bounce (audio regions on the timeline) or select and mute all other tracks and export (MIDI regions on the timeline) to the desktop or another selected folder. From the desktop, you can drag such files into virtual instruments. For example, i can drag audio regions from the desktop into Kontakt or MIDI regions from the desktop into Superior Drummer.
It's not exactly what the OP wishes for, and it does involve a third temporary location (desktop), but it works.
Pro Tools HD Native 2023.12 | HD Omni | iMac Pro 10-Core 3.0 GHZ - 64 GB - 2 TB - Vega 56 | Ventura 13.5 | Sonnet Echo Express SE II for PT HD Native PCIe and UAD 2 Quad PCIe card | Avid Dock and S1
  #17
Old 11-02-2019, 03:14 PM
Philthy Philthy is offline
Could you do this using a VST through Blue Cat PatchWork?
Phil Mann
Silk City Music Factory - CT Recording Studio
  #18
Old 11-02-2019, 04:32 PM
DetroitT's Avatar
DetroitT DetroitT is offline
"VST through Blue Cat PatchWork?"
Nope.
+1 for bring back drag from timeline to plugin
  #19
Old 08-29-2021, 05:44 AM
ejsongs ejsongs is offline
Structure use to have this feature in pt but that was long ago. They broke it and never fixed it sadly.
Ej
  #20
Old 08-29-2021, 05:46 AM
JFreak's Avatar
JFreak JFreak is offline
Actually it was a bug in RTAS specification and they fixed it in AAX, thus the "functionality" was cut off. Cannot get it back without breaking AAX specification. Sorry to bring you bad news.
Janne
VI Drum Sampler with Drag An Drop? Actionmusic Virtual Instruments 4 02-02-2010 03:20 PM
Sampler with drag and drop capability ? micline 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 01-11-2008 12:05 PM
RTAS sampler with drag/drop of regions? fredrick 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-01-2005 12:29 PM
Drag and drop HD-TDM Sampler??? PBJ Pro Tools TDM Systems (Mac) 1 04-01-2004 05:46 PM
Sampler plugin with Drag & Drop from edit window?? goldn 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-07-2003 04:04 PM
