Old 01-10-2008, 12:06 AM
Olixka Olixka is offline
Default Erratic timing with MIDI
MIDI recording / playback in PT M-powered 7.3 is very erratic so I gave up trying to do music with it, and tried just to implement the MIDI click ... on record+playback, in an otherwise empty session.
I'm using PT's inbuilt 'Click' instrument and there are no other MIDI devices connected.
So there should be virtually no demands on the CPU of my 2.6 GHz Windows PC. Delta 66 soundcard. (Audio recording appears to work well.)
The metronome plays much too slowly, and also extremely erratically ...
"click (long pause) click-click-click (short pause) click click (very long
pause) click" etc etc ... completely useless for timekeeping.
It seems to me that the counter is advancing erratically as well. The tiny decimals in the transport window don't advance smoothly.
I've followed all the procedures in the pdf manual and on the instructional
DVD to the best of my ability. Is there some blindingly simple thing I'm overlooking? Could it be related to the dual processor and if so, how do I tackle that? FWIW recording on my old Cakewalk software on the same PC has none of the above problems.
Any help much appreciated.
Old 01-10-2008, 07:51 AM
spkguitar's Avatar
Default Re: Erratic timing with MIDI
Yes, this is actually most likely related to the dual-core processor. Have you applied the Microsoft Dual-Core Hotfix for Windows XP? There's a flaw in the operating system; it was never designed for multi-core processors and must be updated to work properly with them. That update is necessary for Pro Tools to function normally when using multi-core procesors.
Old 01-12-2008, 08:31 AM
Thanks very much indeed. The fix worked very well. A great help.
midi timing erratic even with click on LE 7.3 Greg F 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 28 07-18-2009 03:50 PM
> PT 8 Intermittent, Erratic Audio Timing Howardk Pro Tools TDM Systems (Mac) 2 03-11-2009 11:46 PM
LE 6.0.1 introduces erratic midi behavior LSRdigital 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-06-2003 11:17 AM
Erratic MIDI jperser 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-05-2001 09:23 PM
PT5 midi erratic whilst bouncing.... johnedmonds Pro Tools TDM Systems (Win) 12 07-04-2001 04:16 AM
