h/w buffer size conundrum (9093) (9129)
I have searched through the forums for this very problem and have not have a sufficient answer to it. I just setup my 002R today and the sound comes through alright but when I go to record a track or playback an imported sound file I get this error message:
"The operating system held off interrupts for too long. If this occurs often, try increasing the H/W buffer size in the playback engine dialog (-9093)" so I do that and bring it from 512 samples to the max of 1024 samples. Then I get this message: "Audio processing is with other CPU tasks. If this occurs often, reduing the H/W buffer size in the playback engine dialog may help prevent the problem (-9129)" So you see the contradiction here... I went through the general troubleshooting and all. I did everything that I could do. When I went to the BIOS I could do find what it said to turn off. I tried both my external 7200rpm firewire hard-drive and my internal one. The only USB device that is plugged in is my mouse. I have tried low latency monitoring, 16 bit mode instead of 24 bit and nothing seems to work. I am using ProTools LE 7.1, would it make a difference to install the 7.3 upgrade? I would really appreciate any advice. Thank you =) Here are my PC specs. SiSoftware Sandra System Host Name : JONLAPTOP User : Jon Irizarry Workgroup : WORKGROUP Processor Model : Genuine Intel(R) CPU T2500 @ 2.00GHz Speed : 2.00GHz Performance Rating : PR6784 (estimated) Cores per Processor : 2 Unit(s) Threads per Core : 1 Unit(s) Type : Mobile, Dual-Core Internal Data Cache : 2x 32kB Synchronous, Write-Thru, 8-way set, 64 byte line size L2 On-board Cache : 2MB ECC Synchronous, ATC, 8-way set, 64 byte line size, 2 threads sharing Mainboard Bus(es) : PCI PCIe PCMCIA CardBus USB FireWire/1394 i2c/SMBus MP Support : 1 Processor(s) MP APIC : No System BIOS : Hewlett-Packard 1.06 System : Hewlett-Packard HP Pavilion dv8000 (EX177AV) Mainboard : Hewlett-Packard 30A6 Total Memory : 2GB DDR2-SDRAM Chipset 1 Model : Hewlett-Packard Company 955XM/945GM/PM/GMS/940GML Express Processor to DRAM Controller Front Side Bus Speed : 4x 166MHz (664MHz data rate) Total Memory : 2GB DDR2-SDRAM Memory Bus Speed : 4x 166MHz (664MHz data rate) Video System Monitor/Panel : Default Monitor Monitor/Panel : Default Monitor Monitor/Panel : Plug and Play Monitor Adapter : NVIDIA GeForce Go 7600 Physical Storage Devices Hard Disk : ST98823AS (75GB) Hard Disk : DMI 00GVC0 IEEE 1394 SBP2 Device CD-ROM/DVD : PIONEER DVDRW DVR-K16 (CD 24X Rd, 24X Wr) (DVD 3X Rd, 3X Wr) Logical Storage Devices Hard Disk (C:) : 64GB (20GB, 31% Free Space) (NTFS) HP_RECOVERY (D:) : 9.6GB (1.4GB, 14% Free Space) (FAT32) CD-ROM/DVD (E:) : N/A Hard Disk (F:) : 112GB (112GB, 100% Free Space) (FAT32) Peripherals Serial/Parallel Port(s) : 1 COM / 0 LPT USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C9 USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CA USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27CB USB Controller/Hub : Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller - 27CC USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub USB Controller/Hub : USB Root Hub FireWire/1394 Controller/Hub : Texas Instruments OHCI Compliant IEEE 1394 Host Controller PCMCIA/CardBus Controller : Texas Instruments PCIxx12 Cardbus Controller Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Keyboard : HID Keyboard Device Mouse : Synaptics PS/2 Port TouchPad Mouse : HID-compliant mouse Human Interface : HP Quick Launch Buttons Human Interface : HID-compliant device Human Interface : USB Human Interface Device Communication Device(s) Device : HDAUDIO Soft Data Fax Modem with SmartCP Printers and Faxes Model : Quicken PDF Printer Model : Microsoft Office Document Image Writer Model : HP Photosmart C3100 series Power Management AC Line Status : On-Line Battery No 1 : 100% Operating System(s) Windows System : Microsoft Windows XP/2002 Professional 5.01.2600 (Service Pack 2) Network Services Adapter : Intel(R) PRO/100 VE Network Connection Adapter : Intel(R) PRO/Wireless 3945ABG Network Connection Performance Tips Notice 5901 : CD 1x= 150kB/s; Exercise caution when comparing measured versus published ratings. Notice 5902 : DVD 1x= 11.08Mbps Exercise caution when comparing measured versus published ratings. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. |
Re: h/w buffer size conundrum (9093) (9129)
ok i just updated to LE 7.3 and everything actually seems to be working fine, so if anyone has the same problem try that if you have not already. thanks! =)
9093 and 9129 Buffer Errors | OzelloPete | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 35 | 04-17-2009 11:47 AM |
Hardware buffer errors 9093 and 9129 | bobmcp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-12-2008 05:41 PM |
Buffer error 9129 & 9093 when turn down buffer | StackLife06 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 12-01-2006 09:34 PM |
error -9129 /-9093 and "increase/decrease buffer" | nickgodie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-07-2006 03:59 AM |
9129,9093, etc. Buffer Settings YAHOO!! | runner2 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 02-19-2006 07:04 PM |
