002r problems
I'm running a G5 1.8Ghz with an 002r. It seems as though I'm getting really really limited amounts of processing power. I'm often getting a message that says that it can't retrieve the information form the harddrive fast enough. I used to run an 001 on a G4 867 and the processors went a whole lot farther. If anyone has any ideas on how to optomize.....or if maybe something is wrong i would really appreciate any ideas on how to make this setup a little more impressive......as in impressive at all.
Mike |
Re: 002r problems
iMac G5 1.8/ 10.3.5 / 768 ram Digi 002r / PT LE 6.4 Logic Pro 7 2 OWC 80G firewire drives many nice noise makers |
Re: 002r problems
Are you using a dedicated audio drive? It seems your bottle neck is the drive, not processing power.
--- c
2013 MacPro 3.5GHz 6-core/16GB RAM/OS10.9.2 - PT10.3.8/PT11.1.2 - RME UFX - Apogee Rosetta 200 - and a bunch of other stuff. |
Re: 002r problems
I have gotten this issue with a G51.6/002R when bouncing to disk. I was bouncing 3 mono tracks and one stereo track. 3 monos were bussed to one aux with delay and reverb. Regular Dither on the master. 1024 Buffer size. After 30 seconds, it said it couldn't keep up. Dedicated serial ATA drive. virtually fresh.
I've sent two emails to DIGI; no response. Based on another guy's problems with calling them, I'm not optimistic about it getting fixed or resolved. If you find a solution, post it here.
MacBook Pro Core Duo 1.83 2 Gig RAM OS X 10.4.8 002R/PTLE 7.3.1 |
Re: 002r problems
Hello everyone
I am having similar problems with my G4 and OO2R. I was using a 512 G4 with the 001 and it rocked and processed loads of audio with tons of stability. I am crashing due to lack of processing power all the time. This new machine is way stronger. I have had no luck with Sweetwater or Digidesign. Someone post an answer. Please Sam |
Re: 002r problems
I am using one 160 gig harddrive that is partitioned into 5 chucks. 1-15 gig that holds operating system stuff, and 4 audio holds. (so i can keep different clients separate from one another) Shouldn't the computer see these as separate drives? I've only been running for about a month now, so it seems unlikely that thinks are fragmented already. One of the drives has only 6 sessions from the same band on it.
I have about a gig of ram...but i have been haveing trouble getting the computer to allocate more memory to protools and DAE. (ya know the way where you hylite the icon and hit command-I, It's not letting me do it, any other ways?) thanks for the ideas and any other thoughts you have. -mike |
Re: 002r problems
If ypur on Panther, do you have the processor speed set to fastest in the control panel?
C
"I'm one of the few people I know who knows the few people I know" - CL |
Re: 002r problems
A cut and paste from a previous post ( sorry forgot who)
---------------------------------------------- Sticking to the same eqs and compressors instead of many types can help Make sure that the powerbook gets a good amount of ventilation, (this really enhances the performance) I regularly monitor the pro tools preferences (located at User>Library> Preferences > Try trashing: com.digidesign.protools.plist, Dae Prefs (folder), DigiSetup.osx, PT LE V6.2 Preferences and com.apple.audio.audioMIDIsetup.plist Try also to trash the Volume.ddb files on your mounted hard drives (Located in the Digidesign Databases folder on your HDs) In MacHD >Library>Application Support>Digidesign>trash databases folder (if present) In Apple System preferences: -Open classic Disable "Start Classic when you log in" Under the Start/Stop tab -Set the energy saver setting to "highest performance" -In Network Time and check the box "Use a network time server" Disable any Virus Protection Software Empty the trash, but repair the Disk Permissions on the mac HD before you restart: Launch Disk Utility and check that your disks are HFS/HFS+ than select "repair permissions" Try clearing the PRAM or (parameter RAM): During restart, hold down the "Option", "Command", "P" and "R" keys. Keep holding until you hear the start-up chime three times. Then let go of the keys and let the computer continue booting up In Pro Tools I use a high cpu limit (85 at least, but depending on the situation) And a high DAE Playback buffer (Level 8) And the H/W Buffer size at 256 during the plugin test. There are also threads here on allocating more memory to spesific operations in Osx, but unless youre running too many programs, I dont think this should be nesessary.
DesertDude 1.25 Alu/1.5 ram/10.3.4 PTLE 6.4-002R-Live-Reason |
Re: 002r problems
Partitioning your main drive is not the same as having a dedicated audio drive. Yes, the system sees each partition as a separate volume, but a drive can only do one thing at a time - and you're just asking too much asking it to read/run the OS (and swap files), Pro Tools and to act as your audio drive. You can get a second internal drive for under $100.
Also, I find it really helpul to renice ProTools before starting a session. Type "man renice" in the terminal to learn more about renice and how it works. HTH
Steve Always err on the side of perfection. |
Re: 002r problems
Also, Panther uses a journaled file system by default. Make sure you have journaling turned OFF on any drive you are using for audio recording. It's good for data recovery but bad for performance. |
002r problems | magredc6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 02-08-2006 05:30 PM |
002r problems | magredc6 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-04-2006 12:34 PM |
002R problems PLEASE HELP! | Hazzard | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 06-28-2005 11:39 AM |
002R problems | jimmyjm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 09-06-2004 08:59 AM |
HAVING SOME PROBLEMS 002R | werds mekani | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-30-2003 05:42 PM |
