Protools and Native Instruments Komplete 9
Hello I have a question.
Anyone remember if last year Native Instruments did some promotion for Christmas? like lowering the price for KOMPLETE 8 or add plugins at the bundle ? I want to buy the Komplete 9 and Razor but i dont know if bether wait Christmas if in case NI place razor in the same package! Help plis Thanks Nico. |
Re: Protools and Native Instruments Komplete 9
PT 12, Gigabyte GA-X79-UD3 ATX LGA2011 MB,Intel Core i7-3930 3.2GHz 6-Core Processor,Asus NVIDIA GeForce GT 640 2GB GDDR3 PCI-e Video Card, Patriot Viper 3 Low Profile Blue 32GB (4x8GB),Cooler Master Hyper 212 Evo CPU Cooler, Rosewill Stallion Series RD700 700W Power Supply,Western Digital Caviar Black Internal system/session/samples,Windows 7 Professional 64-bit,Mbox2 |
is the perfect solution!! jajaa thanks
Yes, I pulled the trigger and went NI 9 ultimate for 50% myself.
Make sure you pay attention the the problems in 11 though. Apparently the timing is not so good in Kontakt AAX64 if the buffer is not quite low. Hopefully there will be a fix for this. I'll try to remember to link to the thread after I find it ..... |
here is the thread:
http://duc.avid.com/showthread.php?t=347600 |
Ho
Paul is correct, I am the one who started that thread and Kontakt5 AAX64 can not sync or get the metronome working under PT11HD/11 if the buffer size is bigger than 128 and basically need to be set to 64. We have this problem with the metronome issues on the Scarbee Guitars and the Alicias Keys but not in the rest of the libraries from Komplete Ultimate 9 and the sync issues are fixable if you: 1. Goto "Settings" under the instrument in kontakt 2. Set input Quantize to "Off" Then these issues with the metronome dissapears for us atleast Very starnge indeed and waiting for a fix as soon as possible. It makes the whole VI count advertized in PT11HD pretty hard to like if we cant use a higher buffer setting when tracking vocals and guitars due to latencies so here is to hope! Christopher
Thank you guys!! you are very good people!!
I bought Massive, Razor and Spark !! have very good sounds and the Reaktor works very good Now i have other problem!! XD I can't use my external control midi key for play!! I don't knew what routing i need to do. Im checking my books of protools 101 and 110 but aren't very clear.. My midi key works good in logic and garage band. Its a mydistart-3 pro keys i bought in thooman. Thank Guys!! |
Mac book pro i7 13'' 8 ram 750gigas
protools 11.0.3 i use Mavericks |
Hi
Have you set up your midikeyboard in PT11 http://duc.avid.com/showpost.php?p=2103754&postcount=4 And make sure your device is compatible in PT11 and that you have the latest drivers for the keyboard. And here is an illustration http://duc.avid.com/showpost.php?p=2092986&postcount=11 Post back if this doesn't work Christopher
Okey i can't do this in the track !! you can show my?
http://duc.avid.com/showpost.php?p=2092986&postcount=11 Thanks for you're help :) |
ProTools 8 and Native Instruments Komplete 7 | JayRay | macOS | 1 | 04-01-2012 09:00 AM |
Native Instruments Komplete 7 | Funkle | Virtual Instruments | 7 | 01-28-2011 10:38 PM |
Native Instruments Komplete 6? | Stephen Bond | Pro Tools TDM Systems (Mac) | 8 | 08-01-2010 06:52 AM |
Native Instruments Komplete | Obsidian Dragon | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 18 | 09-11-2009 01:10 PM |
Native Instruments Komplete 3 Help | dunnryte | Virtual Instruments | 5 | 02-28-2008 08:38 AM |
