Hd Omni monitor section bypass
Hello :)
Does any of you know if ist possible to bypass the monitor section of HD omni interface. The thing is that I've got a new 5.1 monitor controller that I've like to use instead... But is it possible, can't seem to find any answers in the manual... Thanks Mark :) |
Re: Hd Omni monitor section bypass
Very simple. You just set your monitor path to "none", and by doing that, all of your analog outs just become normal line outs.
Although if you're just using 5.1, you could still have a stereo monitor path and have enough line outs for the 5.1. |
Perfect, thank you very much!! :)
How about the AES/EBU or Optical out paths; does the same apply (so that you don't have random degradations to your signal)?
Yes. Any output that's not selected as a monitor path is just straight line out, whether analog or digital.
Monitor Section | Hanswurstlsepp | Avid S4/S6 | 36 | 06-06-2014 02:52 PM |
HD Omni how does the monitor section sound | sonixstudio | Pro Tools TDM Systems (Mac) | 0 | 04-22-2012 04:03 AM |
C24 Monitor Section | s0nguy | ICON & C|24 | 6 | 08-10-2004 07:48 AM |
PC monitor section | nworb ecnal | ProControl, Control|24, Command|8 | 0 | 03-15-2002 11:33 AM |
C-24 Monitor section | Rollerex | ICON & C|24 | 30 | 09-18-2001 10:18 AM |
