Kontakt 2 and PT: What\'s up??!!
I have been running the East West EWQLO XP Platinum library which uses the NI Kompakt player. No problems, other than the library taxes my computer. I have a dual 2.7 G5 PPC running PT HD3 7.3.1.
I 'upgraded' to Kontakt 2 because I heard it was way more efficient than the Kompakt player. Kontakt 2 has NOT been cool. Everytime I load an instrument into K2, I get about a 3 second delay! If I go into the PT Set Up window/Play Back Engine and change the H/W buffer size, longer or shorter, things are fine. UNTIL I load another instrument into K2. Same exact thing happens. Crazy! After doing this for about 5 minutes, all of the sudden I get NO sound. I have to go to the PT mixer and change the K2 input to any other input and then things are fine. Uh, until it happens again 5 or 10 minutes later. Of course I am constantly having to go and keep changing the H/W buffer size as well. Any suggestions before I throw away Kontakt 2? Of course NI tech support hasn't answered me at all in the last 3 or 4 days....... Thanks.
Mac Pro 3.5GHz 6-core (6.1 2015) Monterey 12.6.8 64 GB RAM 1 TB PCIe flash storage Pro Tools Ultimate HD 2023.6 HD Native Thunderbolt |
Re: Kontakt 2 and PT: What\'s up??!!
with the same configuration, Kontakt2 and Battery3 are running smoothly here. Never had these problems. NI recommends Buffer size 512 and I have to be on 1 processor/99%. Apart from that have you checked the General Troubleshooting? I remember there were problems with the playback engine settings related to an older MDW-Plugin version. Cheers, Martin PS: The NI-Support over here in Germany has always been very helpful and easy to reach.
Mac Pro 2,4 GHz 12-Core Intel Xeon (Westmere) 32 GB RAM, OSX 10.10.5, HD I/O 16x16 analog, HD I/O 16x16 digital, 192, PT HDX2, PT HD 12.6.0 http://www.pelhamundhaas.de/index2.html http://www.pelhamundhaas.de/vita.html www.3-p.de www.imglashaus.de |
On the track that you have the K2 plug-in instanciated, make sure you have a valid analog input selected on the track.
Anyone else have any ideas?
this plugin runs best using DFD
otherwise it uses a ton of RAM open activity monitor ( utilities folder ) and look at available Memory when you have this problem it is more than likely less than a couple hundred meg's available http://www.soundsonline.com/EWQLSO-P...tes-p-100.html
http://www.studio-techservices.com าำ [email protected]mMitch Berger Tech Services We service ALL Avid products no Problem HD192, 192, Omni, Control Surface, Pre, XMON, 192HD AD & DA / Accel Cards, Everything ALL NEW HD192 AD -DA modification. the difference is incredible... no need to ship the entire unit , fast turn around inquiry using link above Repairs of SSL-Neve- Consoles and Repair ALL Modern & Vintage Gear |
when you experience the delay open the the window "playback engine" and close it again. Now your problem is gone. You may also just toggle the input on the channel and it will take care of the problem... NI Support advised me NOT to use RTAS if I had the possibility of using AUs or VSTs - RTAS is a sick baby for VI's and you'll get a lot more performance out a AU... or VST
2016 MacBook Pro Retina | 16GB RAM | 1TB SSD | OS X Latest - PTHD 12 Latest | 4K LG Thunderbolt Display | Logic Pro 10 |
I am using RTAS VI's every day and NOT getting problems, My only rule is NOT to use NI RTAS plugs which i have found to be a painfull experience. Chris
Regarding the 3 second latency after loading a new patch - Same here. Same with everyone I know who's using Kontakt2/PT. Same thing in Akoustik Piano too...
Quick workaround is to quickly hit the spacebar to start-stop PT each time you load a new patch. These seems to clear somekind of 'buffer' (or whatever). |
Itดs been a while but I do recall that some of the problems with RTAS VIs went away after I extended RAM to 6,5 GB.
I didnดt want to advise you to move to Germany, but calling them might be an option Iดm sure their english is sufficient. Hereดs a number: 0049 30/61 10 35-0 Cheers, Martin
PT presets from kontakt 4 not opening in kontakt 5 | table17 | Virtual Instruments | 0 | 02-06-2012 12:13 PM |
OT: Kontakt 4, 8.0.1, W7... | mykhal c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 10-11-2009 11:43 AM |
Kontakt 2 Stand Alone vs RTAS, Kontakt vs Giga | ryan de topanga | Pro Tools TDM Systems (Mac) | 18 | 05-17-2005 06:36 AM |
Anyone using Kontakt with LE? | mannikin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2005 09:38 PM |
