Macpro Installation
Anyone installing to a new Macpro receive DAE error -4 upon completing installation and trying to open a session.. Hangs during dsi initialization.
This a brand new system I was asked to troubleshoot. Before I start from scratch just want to see if anyone else has had this problem. Thanks System is a Macpro 2GB ram 150GB HDD and 3x 500GB HDD HD3 192 Digital I/O x3 Control 24 Thanks Ben
Never underestimate the power of stupid people in large groups. |
Re: Macpro Installation
I hope you upgraded to the PCIe cards? If so, I would install the Core only and see if it comes up. Make sure you do the Digi Test all cards.
My System is: Mac Pro 3.2GHz 6 Core 32GB RAM 1- HDX 1 - Apogee Symphony Mk2 8x8 1 - HD 16x16 Interface MOTU MTP/AV ------------------------------ Second System Mac Pro 2013 3.5GHz 6-core Xeon E5-1650v2 32GB RAM 1 - HDX 1 - Avid Thunderbolt 3 Expansion Chassis 1 - HD 8X8 Interface MARVINBASS Digital Audio, LLC Ex PT Beta Tester Woodland Hills, CA. |
Yeah that was the first thing I checked,
Cards are Accel Core for PCIe and 2 Accel Cards for PCIe I have checked and rechecked, the cards, their ribbon connections, I have tried with just the core installed in PCIe slot 2 but Like I said, this is a system I was asked to troubleshoot, and they admit that this stuff is beyond their scope of knowledge. So not knowing what they did before I got their, leads me to think its simpler to Wipe the drive Reinstall OSX, and start from scratch. I was just putting the feelers out to see if it were something simpler that was missing that would cause this error DAE Error -4 (PT hangs on the DSI inialization, then crashes, telling me to save and restart the session) Also Digitest crashes when I try to test anything, single cards its starts but crashes 10 seconds into it, all 3 at once crashes immediatley, seleting any of the different tabs causes crash. So if I have issues with that its possibly an OS thing. Thanks Ben
Hey AudioForLife did you find the problem yet? If you did do a reinstall of OSX up to 10.4.8, did you still have the problem?? If so, there may be a bad card or bad ram. If not great!
Hello,
Marvin is right on with his suggestions... the only other thing I could think of (and sounds like most of this has been tried) is to eliminate the core card and see if the Accel card(s) passes Digitest by themselves (without any ribbon cables connected). Also, as mentioned, see if the core card can pass by itself (sounds like you've tried that though). I hope it isn't a PCIe slot or logic board failure with the computer itself (or RAM or card failure as Marvin mentioned). It seems strange that "ALL" the cards and/or system would go all at once.. yet I seem to recall that a DAE 4 error can indicate a possible Digi card/hardware failure? I would try to digitest each card as mentioned (and cable) individually before ruling anything out to possibly isolate the bad card and/or cable/computer. Good luck! len b PS. I'm not a Digi engineer -and correct me if I'm wrong- but I think just one bad card/ribbon cable could bring the system to a halt or cause said DAE error. |
a fresh install of the OS usually fixes this. I've ran into this problem before and you'll just have to start from scratch. Sorry, but I have no better answer. Seems like everything else has been covered here already.
Good luck |
I had the same problem with Mac Pro & HD3 couple of months ago...turned out to be a corrupted Accel Card. It worked with Core and the first Accel, the third card installed caused error-4 & crashing digitest. A fresh card from local distributor cured it. There was also a faulty TDM ribbon cable, which was causing sync error and crash... |
Using carbon copy to move from macpro to a newer Macpro | fourthtunz | Pro Tools TDM Systems (Mac) | 2 | 04-10-2012 02:39 PM |
Installation Problem - "A Pro tools installation has been detected on you computer" | Nikkimac7049 | Pro Tools M-Powered (Win) | 2 | 02-10-2012 07:02 PM |
Update only works on Installation...cannot perform installation on Win7 | xRollinx | Pro Tools M-Powered (Win) | 5 | 02-12-2010 07:35 PM |
MBox 1 Installation Corrupts MBox 2 Installation. Any Ideas Short Of Reinstalling OS? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 10-01-2009 07:03 AM |
Install Leopard from MacPro Installation DVD | TCLguy1 | Pro Tools TDM Systems (Mac) | 20 | 01-05-2009 11:54 PM |
