Old 05-30-2003, 11:50 AM
d_matt d_matt is offline
Default Midi bank select & Program Change
Trying to create a bank select and program change message in PT. I've got the program change part down, but when I go to create the bank select message (with midi controller 32), I'm unable to select this midi controller from the list of automatable midi controllers. The list skips 32.
Am I going about this the wrong way? Under normal circumstances I would simply record myself changing programs, however I'm using the 002 and I have no additional midi interface so I'm doing it by hand.
Thanks a lot for the help, don't know what I'd do without this list.
-Matt
002, PTLE 5.3.2, A7V266-C, XP2100+ (1.7GHz), XP Home
Old 05-30-2003, 12:57 PM
Roy Howell Roy Howell is offline
Default Re: Midi bank select & Program Change
Matt,
I'm watching this thread too, because I have never been able to get the bank select to work for me. I use a now older Korg 01R/W sound module, and though the 'bank' button for it sits conveniently just above my monitor, I'de still like to get it working within PT.
rh music
Old 05-30-2003, 08:21 PM
Mr_Seven Mr_Seven is offline
the controller 0 and 32 work together to send a bank change. not all keyboards work the same so you have to figure out what numbers are needed to change banks for your device (read the manual).
Roy, i looked up the bank change for your sound module and the instructions below should work.
Remember to use a 0 and not a blank
bank A is default ctrl0=0 and ctrl32=0
bank B ctrl0=0 and ctrl32=1
Darren Valen
Cyberdream Studios
Old 05-31-2003, 12:40 AM
Darren, thanks very much!! I'm gonna do that first thing tomorrow (I'm about to nod)... [img]images/icons/wink.gif[/img]
rh music
Old 06-01-2003, 01:32 AM
yup that did the trick. Thanks for your help!
-Matt
bank / program change with VIs typewriter Virtual Instruments 0 11-12-2009 01:08 PM
MIDI Bank Select/Program Change octathorpe Pro Tools M-Powered (Mac) 0 10-13-2008 11:58 AM
Midi Bank select in 7.3 problem a100man 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-10-2007 09:22 AM
MIDI Bank Select Entries Not Being Retained in PT7 jepmus Pro Tools TDM Systems (Mac) 14 09-09-2006 10:26 PM
PTLE 6.0.1 MIDI Bank Select? swheaton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 04-09-2003 02:22 PM
