Old 11-06-2014, 11:53 PM
Stereosurfer Stereosurfer is offline
Default With new Mac Pro, do we still need BlackMagic or AJA? Only for video out.
Hi, I'm new to post production.
With new Mac Pro, do we still need Blackmagic or AJA card for video out?
Do they provide any benefit when the new Mac Pro already seems an overkill for Pro Tools?
Old 11-06-2014, 11:56 PM
Craig F Craig F is offline
Default Re: With new Mac Pro, do we still need BlackMagic or AJA? Only for video out.
the Mac Pro lacks sync refrence
PT11 System Requirements link http://avid.force.com/pkb/articles/C...m-Requirements
Thank you,
Craig
Old 11-07-2014, 02:43 AM
Sorry, I forgot to say I am planning to build a system with Mac Pro, HDX & PT11 HD.
I'm only dealing with ADR and music for the film, no video capturing involved, do I need sync reference?
From the manual (PT 11), it says video playback can be handled by GPU, Mac Pro has two powerful GPU, so the playback should be okay, right? Or is there some problem in the real world?
And it also said, Video Scrubbing only work with Pro Tools Video Window (if no video hardware presented), but Pro Tools Video Window can be set to full screen, so I still have full screen video scrubbing right?
And how you measure the lag introduced by video monitor or LED TV?
Old 11-07-2014, 07:37 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
Well if you do professionally ADR your system must have a reference sync and be genlocked by a single Black Burst generator.
Other wise each time you'll press playback your sync will start / play different.
To be frame edge accurate you got to have a Sync HD unit and Aja IO XT (for using with a newer Mac Pro).
You'll need also to pick up an Aja GEN10 which will generate HD tri-level sync and feed your Sync HD and Aja IO XT.
You will need to get a Syncheck (discontinued) or Catching Sync app for iOS in order to measure the offset in Pro Tools to compensate the latency of your LCD screen.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2021.12 Ultimate ● macOS Mojave 10.14.6
MacPro 2 x 2.93 GHz 6-Core Intel Xeon ● 24 GB RAM
MTRX Studio + MOM ● Sync HD ● AJA LHi referenced by AJA GEN10 ● D-Command ES24
Old 11-07-2014, 11:20 AM
Brandonx1 Brandonx1 is offline
This AJA box Aja IO XT is interesting. Looks like it can derive reference from LTC. Not a new thing but I haven't seen that on a video IO before. Maybe you could get away with not having a sync HD and just a MTC to LTC converter. That way the video is always locked to the Pro Tools frame reference and not the other way around. Just throwing that out there and I haven't tested it at all.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-08-2014, 08:59 PM
reichman's Avatar
reichman reichman is offline
Every time Apple comes out with a new computer, we get all excited about the possibility that native (extended desktop) video might professionally play a video. Even the new Mac Pro 6,1 probably won't. The refresh rate won't be right, and the video will be much less stable compared to dedicated video hardware. On the Mac Pro 3,1 and 4,1 the difference is huge when you use a Blackmagic card compared to extended desktop. Also, you have the benefit of never accidentally moving the mouse or a plug-in window over the picture. Clients don't like that.
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 11-13-2014, 12:53 AM
evs evs is offline
actually, with the new mac pro you just can connect 2 normal computer monitors via dvi..
you can however, connect more if you have thunderbolt monitors that connect direct via thunderbolt (not via an adapter!), or if you connect an vga monitor..
Old 11-13-2014, 02:34 AM
mgoorevich's Avatar
Please see post #2
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
Old 11-13-2014, 03:10 AM
evs evs is offline
yes, of course, but apart from that its may not even possible if you want to have more than 2 monitors..
Old 11-13-2014, 04:12 AM
use a 34" 21:9 for the primary desktop, plenty of screen
Thank you,
Craig
HTML code is On
No video out to Blackmagic intensity pro redsixmix Pro Tools 11 3 01-16-2014 12:02 PM
BlackMagic video Out : HD fine but SD jerky filmsdunjour Post - Surround - Video 44 07-19-2011 02:20 AM
new Blackmagic video products reichman Post - Surround - Video 1 04-20-2009 04:18 PM
Pro Tools with BlackMagic video cards tom_lowe Post - Surround - Video 1 08-12-2007 12:02 PM
Does anybody use Blackmagic Video Card ? Ale Post - Surround - Video 1 05-12-2005 01:01 PM
