Old 04-12-2010, 01:13 AM
Inthebox Inthebox is offline
Default PT HD and Logic Express on same Mac
Hi
I am running PT HD2 7.3 on a dual 2.3 PPC mac, and I want to know if I can install and run a version of Logic express 8 on this mac without problems. I have a very solid HD system, and wouldn't want to compromise this. I use a 96 I/O.
Thanks
-Box
Old 04-12-2010, 01:59 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: PT HD and Logic Express on same Mac
Originally Posted by Inthebox View Post
Hi
Thanks
-Box
Can't see any problems! lots of us run Logic Pro on the same rig. i have always had both installed and working with no problems.
The only area of possible problems is the audio driver, express can't use the DAE driver so you can only use the Digidesign Coreaudio driver which will give you 8 i/o on the Digidesign 96.
If you intend to have both PT and Logic open at the same time then you'll need to run Logic under another audio driver, either the built-in coreaudio driver or buy another non-Digidesign audio interface.
Chris
Producer, Engineer,
www.ukmastering.com
Old 04-12-2010, 02:04 AM
Thanks Chris
This was all I needed to know
-Box
Here's one: Logic Express on Mix system G4 (OSX) SiliconAudioLabs Pro Tools TDM Systems (Mac) 0 04-21-2005 11:23 PM
Logic Express 7 Dalecoz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-03-2004 09:06 PM
using spidf in in logic express mersisblue 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 08-02-2004 09:35 PM
Are you using Logic Pro/Express? zer0to 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 03-17-2004 07:40 AM
I just ordered Logic Express dclark 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-30-2004 09:44 PM
