Old 08-24-2009, 12:17 AM
flommer flommer is offline
Default Possible bug: MIDI Event list program change
Trying to insert a program change in the MIDI event list
I can insert the prg change if I choose the prg # and bank number manually..
but if I click on the right-hand portion of the field, the patch change dialog comes up. When I click "done", the dialog closes and the view is back to the MIDI event list, but it isn't displaying correctly (remnants of the prg change insertion fields are visible on top of the event list), the prg change event is not inserted, and clicking in that window causes a crash.. Changing to another window and then back to the Event list avoids the crash, but no prg change is inserted...
Looking for confirmation...
MacPro3ghz, 6GB, 10.7.5, PT10.3.2, Digi002 factory/toolkit2/PTIEP, 11R
Old 08-24-2009, 03:50 AM
musicalavtech musicalavtech is offline
Default Re: Possible bug: MIDI Event list program change
Mine displayed fine, however it crashed as well.
OSX10.6.8, 1st gen Power Mac,
PT8.0.5, Mbox2
Old 08-26-2009, 02:06 AM
tamasdragon tamasdragon is offline
Can you upload a session file, or post a step by step repro?
It seems to working fine here.
Although I would be able to test it only at the next week, I will test it further if you want.
TD
my blog:Tamas Dragon
Old 08-26-2009, 10:32 AM
Create new session (24/41, wav)
create 1 new MIDI track
open MIDI Event List
click on the menu arrow, choose insert>program change
in the small dialog box that opens, click under "length/info"
The Patch select dialog appears
pick a patch number, click done
At this point, the position fields (bar-beat numbers) from the original small dialog are still visible, and can still be selected and changed. Doing so then hitting enter either causes a crash or makes the little dialog disappear with no program change entered. clicking in the gray header area seems to always cause a crash..
Basically, it seems as if it is not exiting the patch dialog correctly, as at that point it should be done creating the prg change entry, and no prg change is created and the MIDI event list window becomes unstable..
Old 08-26-2009, 11:30 AM
Tritonemusic Tritonemusic is offline
I just tried hitting the Enter button when the field was still selected (ready for data entry). After a few seconds of the spinning beachball, PT crashed. I'm using the latest version of PT8.
• Pro Tools LE 8.0.4cs2, Mbox 2 Pro • OS 10.6.5, Mac Pro 2 x 2.8 GHz Quad-Core Intel, 8 GB RAM • 7200 RPM System Drive, 10,000 RPM Audio Drive, 10,000 RPM BFD2 Drive
Old 09-08-2009, 11:09 PM
Wanted to add this this still isn't working correctly in 8.0.1, but it doesn't seem to be crashing PT anymore... (at least for me)
It just isn't inserting any program change event when using the patch change pop-up..
If you type in the patch and bank number, it will add the change...
Old 09-09-2009, 01:14 AM
It is confirmed here. Exactly the same, except that on my 8.0.1 it does not become unstable, does not crash, but does not insert anything.
Tamas Dragon
Midi Event List Jel 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 01-24-2007 12:07 AM
Can not edit on Midi Event List. OgnKog Pro Tools TDM Systems (Mac) 0 12-04-2005 08:30 AM
Midi Event List problems? clam 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 07-26-2002 02:40 PM
MIDI event list. Where is it? yuterri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-07-2002 01:16 AM
MIDI Event List Issues MichaelL Pro Tools TDM Systems (Win) 1 11-17-2001 01:42 AM
