Old 11-01-2008, 05:19 AM
lumpstar lumpstar is offline
Default 6.4.1 bug ?
Using 6.4.1 with 888's/G4 1.5 MHz, the 'consolidate selection' stays grayed out. I select the regions and open the menu as I always have with previous PT versions but it won't function. Everything else in the same menu works fine. Any ideas?
Old 11-01-2008, 09:34 AM
Scott Goldberg Scott Goldberg is offline
Default Re: 6.4.1 bug ?
Try trashing your preferences and digi databases. Sounds like a session corruption. go to www.jcdeshaies.com (It's located at the top of the window under pro tools TDM on Mac systems stickies).
Scott Goldberg
Gold Recordings
http://www.goldrecordings.com
Old 11-01-2008, 09:42 PM
Thanx, I'll give it a try.
Old 11-02-2008, 06:15 AM
Also, make sure where your file are being parked. I mess up all the time and save something on the wrong drive.
Scott Goldberg
Gold Recordings
Old 11-03-2008, 05:03 PM
DigiTechSupt's Avatar
Make sure that you have the Invert-Duplicate plug-in in your plug-ins folder...
Avid Audio Tech Support
Support FAQ
Old 11-12-2008, 11:12 PM
digidesigner digidesigner is offline
I do not know if this is related, but I often have a similar problem with my 6.4.1 The difference is, that every file-based operation gets grayed out for some reason... the session still plays fine, but copy-paste-cut wont work... I don't know exactly how, but I get it working again within the session without the restart of the program using some tricks like record enabling a track or using scrub tool on different tracks in the session, no rules it just works again at some point. Very annoying indeed.
Old 11-13-2008, 09:22 AM
Have you tried trashing preferences, or testing from a new admin account?
Support FAQ
Old 11-13-2008, 11:05 AM
I was about to ask the same thing, and make sure you shut off PT when doing it.
Scott Goldberg
Gold Recordings
