Old 08-29-2005, 08:58 AM
nelsonmay nelsonmay is offline
Default External Firewire Drive is not a valid audio volum
I hav a new G5 and am a week new to a MAC. I have PT 6.9.2 on OS Tiger 10.4.2. I have tried everyway possible to make a new session on the external drive. the OS sees it and I can access the drive.
In PT....
I get the error Audio drive can't be designated as an audio record volume because it is not a valid audio drive. I went in "windows" in PT, accessed the workspace option.Under the "A" column I can't change the letter from "T" to "R". Again I get the error message. there are a lot of how to's in the answerbase, but they are talkng about having to rip out folders and do re-installs on the OS. I am afraid to go that far with a new MAC.
Does anyone have an easier or more consise method?
Old 08-29-2005, 10:08 AM
Slim Shady Slim Shady is offline
Default Re: External Firewire Drive is not a valid audio volum
Did you read the 4th thread from the top, called "Audio Record or Playback Volume Error Info"?
Old 08-29-2005, 10:23 AM
OK, I can't verify or repir the disk. It was used on a PC with PT befoe I switchedto the MAC. I am going to try to exhaust all opetion befoere I reformat it because I have so much material stored on it. Old Sessions etc.
Old 08-29-2005, 11:14 AM
olddaddymix olddaddymix is offline
Go to disk utility. Click on repair. At this point you are getting ready to format the drive. Format and then try starting a new project. I had this same problem when i first started.
Good luck!
Olddaddymix
Monster Baby Music
powerbook G4 1.33
768 GB ram
MBox
Pro Tools LE 6.7
Lacie 160Gb Firewire HD.
Old 08-29-2005, 12:09 PM
mattshort mattshort is offline
Sometimes this simple fix is overlooked. In the systems preferences under energy saver>sleep, make sure the 'Put hard disk(s) to sleep when possible' box is unchecked and set both sliders to never.
drive cannot be disignated as audio playback/recording volum jboyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-10-2008 08:19 PM
drive cannot be disignated as audio playback/recording volum jboyer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-10-2008 08:03 PM
External Firewire Drive is not a valid audio volum nelsonmay 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-29-2005 08:58 AM
Firewire drive not "valid audio drive" DaleC 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-04-2005 03:04 PM
Updated to 5.1...now firewire drive "not valid audio drive"" blink 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-11-2001 06:23 AM
