Old 04-28-2006, 10:44 PM
Stixntrixx Stixntrixx is offline
Default Problem Bouncing To Disk
Ok, so this is a new one for me:
I'm using the 001 on Pro Tools 6.4 LE with Windows XP. The session is playing back just fine as I'm bouncing to disk (24 to 16 bit, stereo interleaved, converting after bounce). When it's done playing, I'm expecting to see the task bar for the conversion process. But instead, I'm getting this message:
Could Not complete "Bounce To Disk" command because: Assertion in code "\code\azores_handel\alturaPorts\NewFileLibbs\ff\A udio\ff_AudioProperty.cpp," Line 33
Any ideas what this is about? I would appreciate any assistance.
Old 04-29-2006, 12:12 AM
NoRush NoRush is offline
Default Re: Problem Bouncing To Disk
change buffer setting to level 2, default
Old 04-29-2006, 07:56 AM
Tarktones Tarktones is offline
Delete the Digidesign Databases from every disk volume (hard drive or partition) on your system, empty the trash and reboot everything. That should fix the problem.
problem with bouncing to disk mystixboi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-17-2007 03:13 PM
Problem Bouncing To Disk Stixntrixx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-29-2006 04:08 AM
Problem bouncing to disk laguna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 04-12-2006 05:39 AM
problem bouncing to disk nskillzz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 10-16-2005 03:02 PM
bouncing to disk problem... chal7ds 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-13-2005 07:14 PM
