Old 02-05-2009, 04:34 PM
Digitopian Digitopian is offline
Arrow Core audio manager doesnt launch with itunes after using protools
A few weeks ago i upgraded to leopard and pt8 le, but hadn't really opened itunes after a session until a few nights ago at which point i realized that the core audio manager wasnt loading for itunes after closing protools. It would load with various other audio apps such as reason and sound factory but wont open with itunes unless I restart the machine. Is this a known issue, or is there a fix for this? Is this happening to anyone else?
Mac Pro Quad-core 2.6, 5 gig ocz ram,1Tb hd internal, OSX 10.5.7, 2 internal Audio HD,lacie 500 gig external fw 800 drive
Digi 003 rack, PT le 9.0.1, Mac Book Pro 2.4ghz I5, 4 gig ram, PT 9.0.2, Apogee duet
Waves gold, and ssl plugins /Reason4 /miroslav philharmonik /stylus rmx /Melodyne /T-racks3 deluxe / Strike /Massey compressor, DTM /Sound Toys /blah blah etc.
UA610 pre's / Chameleon Labs 7602mkII pre's / Chameleon labs 7802 stereo opto tube compressor/ Mackie hr824 monitors
Old 02-05-2009, 04:48 PM
docbop docbop is offline
Default Re: Core audio manager doesnt launch with itunes after using protools
Happens to me and I just go into setting and flip to Internal Speaker then flip back to 003r and that does it for me.
Steve B.
If you think you can or if you think you can't, you're right.
Old 02-05-2009, 05:25 PM
DigiTechSupt's Avatar
You should not count on the Core Audio Manager auto-launching under Leopard. There are several issues related to Core Audio that we will be addressing in an update, but for now it's best to launch the Core Audio Manager and make sure it shows 'Connected' before launching iTunes (or any other application that you want to use with Core Audio).
Avid Audio Tech Support
Support FAQ
Old 02-05-2009, 05:51 PM
Based on researching other threads i have taken a few steps including trashing certain preference files, as well as launching core audio before launching itunes and unfortunately even after doing that the core audio manager shows connected but it also shows zero clients and i have no sound coming out of the 003r. Have i missed something? btw thank you for such a quick response.
Well at the moment things are now working normally, although I'm not entirely sure why. After my last failed attempt of launching core audio and then itunes, I restarted at which time i launched itunes on it's own with no issues. I then quit itunes and launched pro tools and decided to set the buffer to 512 which i believe is what core audio defaults to. I then quit protools and launched itunes w/o launching core audio and it worked without problem. Wondering if hardware buffer size was the key, I quit itunes, launched protools again and set the buffer to 128 saved the session and quit protools, and again opened up itunes successfully. So currently everything is working normally and although i have no idea why it's working maybe the above information will helpful to someone who understands core audio more than I.
Old 02-05-2009, 06:11 PM
Is your Sound control panel set to Digi HW in the Output tab? It needs to be, as that's where iTunes determines it's output.
Support FAQ
Old 02-05-2009, 06:43 PM
I just double checked and it is indeed set properly. Perhaps the setting was changed at some point during the upgrade? All i know is that at the moment all is well. I just hope it stays that way. Thanks for your help Digi!
Old 02-11-2009, 05:19 PM
gregtannen gregtannen is offline
I'm in the exact same problem (oh so frustrating) and the fixes aren't working.
I'm on a Dual G5 PowerPC Mac, running PT8, Leopard, and have a Digi002 rack.
I manually launch Audio Core Manager.
Launch iTunes.
And iTunes still doesn't play through my speakers like it used to. (it plays through the internal computer speaker).
What else should I do? Argh.
Old 02-11-2009, 05:38 PM
man versus tv man versus tv is offline
Gregtannen - I am running Protools on exactly the same set up as you. I struggled with this problem and this was my fix: Turn off your computer, turn on the 002 FIRST, then turn on your computer. For some reason when I did that, my computer finally let me set my audio output to 002 and core audio automatically launched with itunes. If this doesn't help then I guess my fix was merely a coincidence. I dunno, give it a try.
Old 02-13-2009, 08:34 AM
Holy Moly. Thanks! Turning the 002 on first before booting up the computer totally worked.
Old 02-13-2009, 01:41 PM
jambirn jambirn is offline
Mine works after I shut down AND turn the 002 on first. It's a pain, as I like to put my computer to "sleep" often. Please fix this, Digi!
002 pro tools 10.3.5 Avid Core Audio Manager not working with safari or iTunes? nate9 FireWire & USB Audio Interfaces (Mac) 1 07-19-2013 08:25 AM
Core audio manager routing question - iTunes to b15&16? Blues Bird macOS 4 07-05-2013 04:46 AM
Disable Core Audio Manager auto launch....other apps rexdigital Pro Tools TDM Systems (Mac) 3 05-15-2008 10:46 AM
itunes 7.5 and digi core audio manager DjA 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-08-2008 09:25 AM
Core Audio Manager Does Not Launch *DELETED* truetoneman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-29-2006 07:30 PM
