HDX Hybrid tracks going out of time
I've noticed this a few times now... record a vocal take with the thunderlight on... finish the take and playback and it's typically fine... however if i am silly enough to switch the hybrid mode off while its playing back quickly after the recording i find it can make the audio out of time... put it back into dsp mode and the timing is back to where the take was... beasically i often cant take tracks out of DSP mode once recorded because their timing gets messed up....
i think it is something that has moire chance of happening if done very soon after a take or if switching DSP mode on and off during playback... Still isnt it supposed to be able to work like this? anyone else seen this?
System Details |
Re: HDX Hybrid tracks going out of time
quick update.... copy that audio file to a new track and it seems to work normally ...
then drag it back to the original 'corrupted track' and it's back to normal there too... weirdness
System Details |
Hybrid Mixer and HDX - need a separate "mixing" high-latency DSP mode for tracks | Skwaidu | Pro Tools | 2 | 10-24-2021 08:51 AM |
Use Behringer x32 compact and Motu Hybrid 896mk3 with Protools at the same time | albikat2014 | FireWire & USB Audio Interfaces (Win) | 2 | 02-08-2015 07:51 PM |
Clip Gain won’t update in real time during playback on Elastic Time tracks | yanos | macOS | 0 | 06-03-2012 03:48 PM |
Dummy Time: Strike And Hybrid Not Showing Up | LightWing | Windows | 1 | 02-24-2011 08:09 PM |
Does Hybrid have a Time Variant Filter? | StinkyStan | Virtual Instruments | 14 | 05-24-2009 02:45 AM |
