Old 03-25-2010, 01:38 PM
DeyBwah DeyBwah is offline
Default Hardware buffer error during playback...
I seem to be having playback errors on sessions I never did have them on before. Not sure what has changed besides formatting and reinstalling W7 as OS. But even still I wasn't getting these errors when I had W7 in the past.
I'll run through the optimizations and post my results, but I wanted to gather some feedback before the task tonight. All suggestions are welcomed with open arms and smiles!
"One should not pursue goals that are easily achieved. One must develop an instinct for what one can just barely achieve through one's greatest efforts."
-Albert Einstein
Windows 7 - Reaper 3 - Lynx Aurora 16 - RME HDSPe AES - DigiMax FS - Eureka - Axiom Pro - Yamaha HS80Ms + HS10W Sub
Old 03-25-2010, 01:42 PM
sw rec sw rec is offline
Default Re: Hardware buffer error during playback...
PT for Win 7 is BETA so you almost have to expect trouble like this. But without a Sandra report it's hard to say. Are you recording to, and playing back from, a separate hard drive from your OS drive? You should be.
But what interface, what version of PT? We must have info!
Old 03-25-2010, 02:00 PM
002R, PT 8.0.3cs1, recording to external HD...
The other thing that has changed recently.. my external was using a USB connection and had no playback issues. I recently switched it to use a Firewire connection thinking it would be an improvement.. Maybe I shouldn't fix it if it ain't broken.
As for a Sandra report, I'll have to run it when I get home.
-Albert Einstein
Old 03-25-2010, 02:32 PM
caruso7r caruso7r is offline
I'm testing on W7 with the cs2 patch and the optimizations are important. Here's a screenshot of the performance tweaks that are working for me and also I have had to disable both network interfaces to avoid the errors. You can read This thread if you're interested in how W7 64bit is working for me so far. I'm curious if you're using the 8.0.4 driver that DIGI recommends. I'm not at the moment as the thread I posted will explain.
John
Pro Tools 12.5
Macbook Pro & Windows 7 Ultimate 64 Bit
Old 03-25-2010, 02:39 PM
Having the wrong firewire controller can cause that little malady. it should have a TI chipset in it, and the drive needs an Oxford chipset.
Buffer constrol. Hardware vs. Playback engine Sidhu Windows 0 05-01-2011 07:08 AM
PT 9 lowest playback engine buffer for non Avid hardware? SaschaP Pro Tools 9 0 11-05-2010 08:42 PM
PT LE 6.4 w/OS x 10.3 Hardware Buffer Error rshook 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-10-2008 05:14 PM
Pro Tools - 7.1 Problem - Hardware Buffer Playback smithdave101 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-14-2006 07:27 AM
Hardware Buffer Error buddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-29-2000 05:46 PM
