Producer Factory
Hello,
I experienced te following problem: I installed Pro Tools LE version 7.4.2 on a MacBook Pro with OS 10.5.3 running on it. I installed the following plugins: 1. XPand! (I upgraded this synth and it works fine...) 2. Hybrid (version 1.0 doesn't seem to work and isn't visible as a plugin in the list of virtual instruments in Pro Tools LE) 3. Strike (is visible, but doesn't seem to work due to lack of upgrade -> availabe at mid July) 4. M-Audio KikAxxe (works fine!) 5. Producer Factory (Bombfactory). Question about this last one: installation was OK, but I can't find the plugins in the list of plugins in PT. Does PT 7.4.2 support these plugins from the Producer Factory Bundle? Thanx! |
Re: Producer Factory
Sorry, unfortunately no help from me, but partly the very same question: just downloaded and installed Producer Factory as well, but Joemeek etc are nowhere to be found...When lauching PT the are "passing" and seen on-screen bootup, but when opening the mixer in order to use them...nothing.
Something I did wrong here? Ilok seems to be ok as well. The icons at the plugin-folder are somewhat different than others ones as well.. OSX 10.5.5, MBox2 Mini, UAD2 Duo Flexi and ingnition pack are former installations. Best rgs, -w- |
You both probably need to do a little more digging and find the most recent versions of the plug-ins you're having problems with, download the updaters and install them. If the plug-in version is too old/out of date, it won't properly show up in PT.
Yup, You are absolutely right.
The following should be installed accordingly. It works then. Found quite a few threads concerning this matter already when looking more closely. http://www.digidesign.com/index.cfm?...4&itemid=24497 Thanks anyway for your reply and have a wonderful x-mas time! -w- |
Producer Factory Pro | Psychonaut4 | macOS | 0 | 10-25-2011 04:56 PM |
Producer Factory and MP 9 | Headlow | Pro Tools M-Powered (Mac) | 0 | 10-06-2011 09:29 AM |
Producer Factory Pro | Psychonaut4 | Pro Tools 9 | 3 | 02-10-2011 01:44 PM |
003 Factory/Producer Factory Pro 8.0 Upgrade? | Gothboy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 08-07-2010 02:45 PM |
Producer Factory Pro | skell | General Discussion | 1 | 11-11-2009 10:53 AM |
