Old 11-16-2006, 08:39 PM
Avid's Avatar
Avid Avid is offline
Administrator
Default Pro Tools HD 7.2cs2 Update
Available for download from the Pro Tools CS Updates quick link in Support & Downloads:
www.digidesign.com/support
Or this direct link:
Pro Tools HD 7.2cs2 for Windows XP
Pro Tools HD 7.2cs2 for Windows XP contains the following:
Fixed: Reopening a Session Containing Video Files Could Cause Them To Be Overwritten (Item # 82397)
A problem with file name suffixes could cause a second video record pass to replace the first one after the session was reopened.
This would happen after recording to a "Save As," "Save A Copy" or to video tracks that had been imported to a new session, and then saving, closing, and reopening that session.
Fixed: "Auto-Write On Stop" Modes Could Improperly Overwrite Data (Item #82271)
"Auto-Write On Stop" mode (to start, to all/selection, to end) would affect any automation write, even if it had been automatched out.
Fixed: Original Timestamps of Imported Avid .WAV Files Would Be Reset Upon a Subsequent Session Opening (Item #81997)
This bug would not occur if the audio had valid soundroll timestamps in the Avid source bin.
This bug would prevent the automatic matching features of field recorder workflows in Pro Tools.
Fixed: Embedded OMF Sequences Can Play Back Incorrectly (Item #82926)
When the OMF file had been set to "Read only" on Windows or "locked" on Mac, every region played the same audio data. Attempting to re-import the OMF after the session was opened resulted in a message, "Some regions were truncated or removed from the region list or timeline because they referred to files which are too short."
Fixed: Laying Back Audio Using MachineControl Will Engage Pre-Read Mode on a Sony DVW-500 (item #81478)
Note - this occurs when using "insert" mode in the MachineControl track arming window.
Fixed: After import of a 23.976 or 29.97 OMF or AAF, Regions Could Be Incorrectly Placed on the Timeline (Item #83338)
23.976 OMF was affected
3- and 4-perf 23.976 or 29.97 OMF and AAF were also affected
Fixed: Importing and Converting an MXF Audio File to WAV via Drag and Drop will Prevent Session from Being Saved (Item #83900)
The problem would only happen when a conversion was required or forced.
The problem would not happen when using the "Import Audio" dialog to import/convert the file.
Administrator
Old 11-17-2006, 11:10 AM
Brandonx1 Brandonx1 is offline
Default Re: Pro Tools HD 7.2cs2 Update
Hi Digi and all,
I've been working with cs2 for about 5 minutes and found a show stopper. Anyway, I could not stop the transport from playback. It just keeps playing. I tried the transport on the C8 the GUi and the spacebar. Nothing stopped PT from playback. Nice, I was writing automation in touch latch for a while and could not get PT out of play so I overwrote a minute of eq I didn't want to write.
Brandon Howlett
Vibe Audio Post, Inc.
Re-recording Mixer
Custom Build CPU, HDX 1, Omni, 192 I/O Digital
S6 M10 24 fader
Satellite Mac Pro, HDNative, 192 I/0
Black Magic HD Extreme
Old 11-17-2006, 01:17 PM
DigiTechSupt's Avatar
Hello,
I have tested this by writing several automation passes of different lenghts using all modes and I have not had a problem stopping the transport with the spacebar, GUI, or Command 8. We have seen corrupt Digidesign Databases cause this problem in the past. I would recommend trashing the database folders from the root level of each drive and reboot. Please reply if this does not clear the problem.
Avid Audio Tech Support
Support FAQ
Old 11-17-2006, 01:24 PM
That could very likely be the cause. I just trashed everything. BTW, seems like you made some big fixes to Digibase. I'm not getting the access violation errors I was getting with cs1 when indexing drives. Cool. Just what I and everyone needed.
Thanks,
Brandon
Brandon Howlett
Re-recording Mixer
S6 M10 24 fader
Old 11-17-2006, 04:40 PM
beggehorn beggehorn is offline
Another minor observation...
After running the installer, a copy of the cs1 readme PDF is left on the desktop instead of the pdf for cs2.
Windows 10 Pro x64
Avid HDX running PT Ultimate 2020.x
ASUS WS x299 SAGE 10g
Intel i9-10980xe
64 GB DDR4 3200 RAM
Matrox C420
Avid Artist Mix
Pro Tools HD 7.4.2cs2 Update - Important Alert for D-Command Users Avid ICON & C|24 0 12-04-2008 01:57 AM
Pro Tools HD 7.4.2cs2 Update - Important Alert for D-Command Users Avid Technical Alerts 0 12-04-2008 01:55 AM
Pro Tools HD 7.2cs2 Update Avid Pro Tools TDM Systems (Mac) 0 11-16-2006 08:35 PM
Pro Tools LE 6.9.2cs2 Update Avid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 43 08-22-2005 10:26 AM
Pro Tools 6.9.2cs2 Update USB issue?? Armando Pro Tools TDM Systems (Mac) 1 07-21-2005 05:23 AM
