Old 07-06-2005, 12:06 AM
fuabond fuabond is offline
Default playback buffer size error PLEASE HELP
HI EVERYONE, I NEED HELP, I am runing my 002 console protools 6.7 on a G5 dual 2gig processor with 1 gig ram and I am getting the buffer size error message all the time with any session, even without running any plugins. Its ceazy, it just stops in the middle of a recording, and I have my buffer size set at 1024 and 99% of cpu ussage. I also have a diferent maxtor internal hard drive where I record. I have read eveything but I don't know what to do. I need some advice.
Thanks a lot
Felipe Ibarguen
Old 07-06-2005, 01:17 AM
hatteras hatteras is offline
Default Re: playback buffer size error PLEASE HELP
Maybe download the new version 6.9 PTLE
Also, Check your BIOS. I don't know about mac so much, but Windows machines have hyperthreading that must be disabled in the BIOS at start-up to run PTLE.
Other than that....you got me.
Old 07-06-2005, 04:40 AM
reefer reefer is offline
Hi
Well good to see not only P.C guys suffer with this.
There are many reason for this.
Have you installed the C.S8 update for P.T 6.7
Is you O.S correct max 10.3.8 tried and tested.
Is the recording drive external and not your system drive.
Is your drive fragmented. Run Nortons system works.
Try dumping you DigiData base on each drive empty recycle bin restart.
Do a search under the forum as many ppl seem to be getting this error.
Old 07-06-2005, 10:29 AM
DigiTechSupt's Avatar
Also, try all the steps in the 'Setup and General Troubleshooting' sticky - make sure energy savers are off and that processor performance is set to 'highest'. Also try reducing CPU usage to 90% - sometimes having it set to 99% can cause unexpected errors.
Avid Audio Tech Support
Support FAQ
playback error buffer size bryced87 macOS 18 07-04-2012 01:33 AM
Another H/W Buffer size/ Playback -6086 error jawsont 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 08-25-2010 05:42 AM
Playback engine buffer size error constantyly... PLZ HELP kazanz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 09-11-2009 02:14 PM
H/W Buffer Size error -6086 recording/playback DougConner 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-30-2009 04:24 PM
Error -9093 "H/W Buffer Size" in the playback Engine Dialog Don Anger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 04-22-2007 10:51 AM
