Old 10-22-2015, 05:52 PM
angelo panetta angelo panetta is offline
Default Anyone using Blackmagic Decklink mini monitor?
I installed the Blackmagic decklink mini monitor card in my 2009 mac pro running Yosemite. I am trying to run video out of my avid protools 12 to TV. I keep getting this error:
"The Video Engine reported an error. More information is in the Video Engine log file"
Guess what I need to know is how to configure. what are the proper setting in the Desktop Video system pref. It also seems to be effecting the sync in my Protools. Didn't think I need black burst. I removed the card but still get the same error message.
Anyone ??
thank you
Old 10-22-2015, 06:33 PM
spoons's Avatar
spoons spoons is offline
Default Re: Anyone using Blackmagic Decklink mini monitor?
I haven't got that BM model but may be try an earlier version of Desktop Video. I'm on 10.3.7 which works for me. Newer versions don't.
I've never found that I need to change any settings Decktop prefs.
Richard Spooner
Ultimate 2021.3, S1, Dock, Mac OS 10.15.7, MacMini 3.2 Ghz 6-Core i7, 64gb RAM.
www.spoonsound.com
Old 10-22-2015, 06:37 PM
Thank you spoons. Any possibility you can see what your desktop setting are?
I'll see if I can find v 10.3.7
Old 10-22-2015, 06:43 PM
I found v 10.3.7. I'll let you know how it works out.
Thx
Old 10-22-2015, 07:49 PM
I should also mention I'm trying to use the SD output not the hdmi.
Old 10-22-2015, 11:33 PM
Pythagor Pythagor is offline
As far as i remember mini monitor card support was added starting from particular driver version ( don't remember which one) and it is indicated in corresponding What's New document on Blackmagic site. BTW we tried mini monitor on 10.8 and haven't get any luck.
Old 10-23-2015, 02:09 PM
spoons's Avatar
So I can use the Component out, as well as the HDMI fine. But if I select "output processing, HD to SD" it hates it.
My settings are
Output: HDMI & Component
Default: HD 1080p 23.98
Output Processing: Off
Richard Spooner
www.spoonsound.com
Old 10-23-2015, 03:50 PM
my settings are pretty simple: see attached.
I reinstalled my PCIe card. No more error and sync seems to be good. Just not video output now. I've tried every setting.
What QuickTime codec do you use for your 1080p 23.98?
File Type: jpg Screen Shot 2015-10-23 at 6.48.39 PM.jpg (48.5 KB, 0 views)
File Type: jpg Screen Shot 2015-10-23 at 6.48.34 PM.jpg (44.3 KB, 0 views)
Old 10-23-2015, 08:15 PM
spoons's Avatar
DNxHD 36
Richard Spooner
www.spoonsound.com
Old 10-24-2015, 01:44 AM
8dB.co.uk 8dB.co.uk is offline
It isn't an SD output, it's SDI, which is quite different. Are you expecting to get a composite video out from the BNC?
Pro Tools Utimate 2018.7, on -
i7 5820k 6 x 4GHz (12 threads), 16GB DDR4, Win 10 Pro, BM Mini Monitor PCIe, GTX 660Ti 2GB;
Dell Laptop, i7 4x3.6GHz (8 threads ), 16GB DDR4, Win 10 Pro, GTX1060MaxQ 6GB;
"Plan B" - i7 6700k, 4 x 3.4GHz, 16GB DDR4, Sierra, AJA Kona LHi, GTX 1050Ti 4GB.
RME FireFace802 + ARC, RME Babyface
Avid D-Command, Artist Control, V-Control, Korg MicroKontrol
7.1.2 Presonus Monitors
HTML code is On
AJA T-Tap vs Blackmagic Mini Monitor test MIKEROPHONICS Post - Surround - Video 58 11-01-2015 11:03 AM
HD 10.3.10 PCI Overflow with Blackmagic Decklink Mini Monitor rantanplan Pro Tools TDM Systems (Mac) 12 08-16-2015 01:55 AM
PT 10 & Blackmagic UltraStudio Mini Monitor Fedenev Post - Surround - Video 10 08-02-2014 10:34 PM
Have anyone use the BlackMagic Decklink Mini Monitor M-ManLA Post - Surround - Video 7 08-01-2014 06:12 AM
Blackmagic Mini Monitor WORKING with Pro Tools 11 mattsamperi Pro Tools 11 0 11-12-2013 07:44 PM
