Old 11-25-2014, 05:55 AM
jacko's Avatar
jacko jacko is offline
Default Re: My tour with S3L
I borrowed a different S3L, this time upgraded to 4.5. I love the new features. There is one strange thing about the unit I have though... green LEDs above scribble strips are much darker, barely lit. All other colors are bright lit (blue, red, purple). Also, there is no yellow - channels that are yellow on the screen have red LEDs on S3. Can anyone check their units?
UAD Apollo x16,
UAD Apollo Twin Duo,
UAD Octo Thunderbolt,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Arturia Beastep for DAW control,
Former Pro Tools HD user (from V7 until V12.6).
Old 11-25-2014, 07:45 AM
iirth iirth is offline
Sounds like there's an issue with the green LED's on that S3.
I use yellow to indicate drum channels, they light as bright as the others.
Old 11-25-2014, 07:55 AM
Davoetta Davoetta is offline
Same here - no problems with the LEDs
Old 11-25-2014, 12:56 PM
jacko's Avatar
That's right! Yellow is combination of red and green, that explains it.
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
Old 11-25-2014, 02:30 PM
jacko's Avatar
I found it!
I fixed it by resetting LED settings in S3 utility mode described here: http://avid.force.com/pkb/articles/e...ontrol-surface
It turned out that green LEDs were turned down to its lowest setting for some reason.
UAD Apollo x16,
Mac Mini i7 2018,
Reaper DAW,
Presonus Faderport,
  #16
Old 11-26-2014, 02:45 AM
Valentyn Valentyn is offline
Probably its owner hates green...
  #17
Old 11-26-2014, 08:17 AM
Originally Posted by milaszewski View Post
...I fixed it by resetting LED settings in S3 utility mode described here: http://avid.force.com/pkb/articles/e...ontrol-surface
Very cool, thanks for reporting back. That link may be useful in the future.
  #18
Old 11-26-2014, 08:25 AM
A slight aside:
Is anyone else bothered by the refresh rate of the yellow segments in the channel meters? Every time my eyes scan across the console, I can see the yellow segments flicker red. Others have noticed this too, while looking over my unit.
Is there a PWM setting for the LED's that can be changed, perhaps similar to the process described in the link above?
The best fix I've found so far is to keep things out of the yellow. ;-)
New School Tour? EarnestBliss 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 07-11-2003 11:43 AM
OT: did anyone go to the M-Audio tour? tommydee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-24-2002 02:41 PM
Digi Tour and PT LE 5.1 nz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 11-11-2000 12:18 AM
oo1 on tour lespaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-25-1999 11:16 AM
oo1 on tour lespaul 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-20-1999 02:48 PM
