PT9 crash when I change buffer
Hello boys. I have a problem with PT9 (on Win7 64bit, Intel quad core, 8Gb ram DDR2): starting from an open project (44.1/24 bit), buffer set to maximum (1024) and latency compensation set to maximum, I'm going to set the buffer to a minimum (64). Whan I play, I hear several crops, and progress is jerky (I think it depends on the use of plugins that require compensation). Trying to return the buffer to 1024, the system crashed and I have to reboot with the reset button on PC (in fact the traditional CTRL + ALT + DEL doesn't work). I updated to 9.01, but the problem persists. Any ideas? Thanks
Simonluka |
Re: PT9 crash when I change buffer
Post a Sandra report as described here: Help us Help You - READ THIS Before Posting!
Sorry but I can't install softwares on this pc. I write informations about the system (I hope it's enough):
- Asus Commando + Intel Quad Core 6600 - Win 7 64 bit Home edition - Digidesign 003 Rack - Pro Tools version: 9.01 - 8Gb DDR2 667 (Corsair) - 1 hard drive Eide (S.O.), 1 hard drive sata (music projects), 1 hard drive eide (storage). - ATI Radeon 3600 HD (dual head) - iLok - cables FW400 between 003R and firewire port (on the motherboard). Firewire chipset is Texas instruments. - Uad 2 Solo on PCIe slot The problem there wasn't with 8.X version of PT LE! Thanks |
I have only seen this when running multiple VIs, mostly "Play" or "Kontakt". It seems to be related to RAM allotment.
Why? So, what can I do?
Are you running multiple Virtual instruments?
Yes in some project, but I also have the problem when I work with a project with just audio tracks!
ProTools 8 Won't Startup, Can't change sample rate, Can't change h/w buffer size! | Nickford | Windows | 0 | 05-26-2013 11:20 AM |
Buffer-size change causes PT10.1.1 to Crash | jayprotools | macOS | 1 | 04-13-2012 10:36 AM |
Buffer won't change | kivaz | Pro Tools M-Powered (Win) | 1 | 09-01-2010 11:35 AM |
PT8.0 Crash on CPU Change | ElectricGhost | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 07-28-2009 12:09 PM |
pt mpowered crash when I try to change the buffer | asylanten | Pro Tools M-Powered (Win) | 4 | 01-03-2008 01:12 PM |
