64 Bit Pro Tools is now a MUST!!!!!!!!!
I don't know what changed but everyone of my sessions reaches the "Critically Low On Memory" and asks to save and restart. I have been using HD for 11 years now, and have had way bigger sessions and have never hit this point. Until now
I have 8 gigs of memory, and looked at the Activity Monitor 56% is at idol Why is memory all of a sudden a issue????????? Is it the pretty Graphics??????? We need to unlock that 3gig limit in 32 bit mode. I can't deal with all the restarts.... At least it isn't crashing....... |
Re: 64 Bit Pro Tools is now a MUST!!!!!!!!!
Any chance you've recently begun using more samplers, virtual instruments, or drum hosts than usual?
That'd do it... S..
"it's not about making the changes, it's about playing ideas in time" Scofield... |
Make sure you enable "Memory server" in Kontakt 4. Then ALL your Kontakt Sample RAM will stay outside Pro Tools. If more VI´s use this excellent method the 32 bit RAM limit won´t be a problem.
Kontakt, VSL ,Spectrasonics use this feature. But we are longing for PLAY2,BFD2,Superior to follow.
iMac Pro - HDX2 - Mojave - AVID HD I/O x7 |
Plays does something similar also already
Hosting your VIs in something like VE Pro will unlock all of your RAM also. Works like a charm.
Vi's do it to but I usually bounce to audio then get rid of the VI.
It is all audio and just mixing with TDM, RTAS, and UAD and when I just about reach the point of a full mix. I get the error. I then have to start getting a balance with my TDM, RTAS, and UAD plugins. Meaning I change the voice count around and restart a few times. Then change RTAS to TDM or TDM to RTAS. Then restart a few more times. Then I find the sweet spot mean while a hour as gone by and I can finally bounce a ruff. I also get the" There is not enough memory to save the session" so I deactivate a few tracks then, Save, then reactivate them. It is such a waste of f**king time!!!!!!! |
It works flawless. Maybe the horror was back in the UAD 1 days. I love the HD2 and UAD Quad combo. I don't run out of Voices anymore. Only Frick'in memory. I love the UAD so much I am thinking of selling my Mercury TDM bundle. Wow I never thought I would say that.
But since I saw the lightpeak demonstration on Pro Tools HD native I will wait to see what may come out that. |
AVID has stated elsewhere in this forum that they ARE working on 64-bit Pro Tools.
http://duc.digidesign.com/showthread.php?t=240742 Quote:
