Old 12-07-2004, 03:54 PM
georgedk georgedk is offline
Default quick key question
what's the quick to import video?
Old 12-07-2004, 04:26 PM
jimlongo's Avatar
jimlongo jimlongo is offline
Default Re: quick key question
There isn't a key command. There is a menu selection under Movie menu > Import Movie . . .
You need a macro program like Quickeys to assign a key command to it.
noise | jimlongo
Old 12-07-2004, 04:49 PM
Old 12-08-2004, 04:16 AM
steppenwolf68 steppenwolf68 is offline
you don't need a macro program to do this!
just do the following (this only applies to MAC OSX):
-go to system preferences
-click on "keyboard & mouse"
-go to "keyboard shortcuts"
-hit the button "turn on full keyboard acces"
-hit the "+" key
-select Pro Tools as application
-in "Menu Title" enter the desired menu as it appears exactly
in the Pro Tools menu bar (in this case: "Import Movie...")
-now in "Keyboard Shortcut" enter the desired key command
-voila, you're there !
after doing this the shortcut will even appear in the Pro Tools menu bar, but
be careful not to use existing key commands for they will be overwritten by
this procedere
hope this helps
steppenwolf
Old 12-08-2004, 06:21 AM
martian martian is offline
exciting tip! was looking for one for bounce to disk..
so these will only affect pulldown menu items? can we change the protools ones too? so we cound change the undo to be more like photoshops for eaxmple?
will look at this tomorrow!
Old 12-08-2004, 08:39 AM
jimlongo's Avatar
I stand corrected!
But I do believe if you want to do serious key sequencing you will need to look into a third party macro utility.
noise | jimlongo
Old 12-08-2004, 12:53 PM
geitz geitz is offline
Just to clarify further, this only works in OS 10.3.X. Jaguar users are out of luck.
Peace,
Greg
Greg Geitzenauer
mixer/editor
Rumble
Minneapolis, MN
HTML code is On
quick question - Mbox Mini question - i forget JRup 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-18-2009 02:55 PM
quick question needs quick answer SublimeAndy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-27-2005 09:44 AM
another quick key question georgedk Pro Tools TDM Systems (Mac) 3 12-08-2004 02:32 AM
Quick question tonyharp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 12-09-2002 10:07 PM
Quick quick quick DSP farm card Question Mr335 Pro Tools TDM Systems (Mac) 1 12-06-2002 07:37 AM
