Old 12-27-2020, 04:37 AM
Rob Hannon Rob Hannon is offline
Default Pro tools Carbon and ADAT
Hi guys
I'm currently undergoing a major studio upgrade and I'm hoping that it wont be too long before Avid develops a windows version of Carbon.
I understand that Carbon can handle 16 tracks of ADAT inputs along with its own 8 channels of Mic pre's.
I have a 16 channel analog mixing desk which I still want to use however my current AD/DA convert is a MOTU 24 I/O which uses firewire. I'm looking to replace this with something that can convert the tape outputs of the mixing desk into ADAT which I can then plug into the Carbon ADAT inputs thus only using 1 interface (I don't want to use ASIOforall and multiple interfaces).
I don't mind several interfaces as long as they are connected to Carbon and not directly to the computer.
Any suggestions would be welcome.
Many thanks
Rob
Old 01-02-2021, 09:39 AM
trimix trimix is offline
Default Re: Pro tools Carbon and ADAT
I just installed Carbon this week and was using a MOTU 16A previously to interface with my 16 channel Trident. The MOTU will continue to be my console interface, just used in stand-alone converter mode and connected to Carbon via the ADAT i/o.
All the DSP processing on the MOTU inputs remains available when running stand-alone and can be controlled by a web-browser connected over wi-fi.
Old 01-02-2021, 12:15 PM
JoelG's Avatar
JoelG JoelG is offline
As I undertand it, the reason there is no Windows support for the Carbon is Windows does not have native AVB support. Hopefully that comes some time, but I wouldn't buy the Carbon expecting it to be soon (it may never happen).
See this thread: https://duc.avid.com/showthread.php?...carbon+windows
Joel
Jam Space:
HP Elite 6300 / Core i5 3770 / 24GB RAM / Win 11 Pro
Pro Tools HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 11 Pro
Rig:
Eleven Rack / ART SLA1 / Two 2x10 Passive Monitors / FCB1010 w/ EurekaPROM
Old 08-13-2021, 01:19 AM
darkwavo darkwavo is offline
Originally Posted by Rob Hannon View Post
Hi guys
Many thanks
Rob
Are there sample rate limitations on ADAT connection with Carbon ???
Old 08-13-2021, 03:53 AM
Standard 2 port ADAT setup - 16 channels at 44.1 and 48, 8 channels at 88.2 and 96 and 4 channels at 176.4 and 192.
Old 09-24-2021, 06:10 PM
Matt Hepworth's Avatar
Matt Hepworth Matt Hepworth is offline
I currently use 16 channels of Symphony I/O, but also briefly used an AD16X. Both are excellent options and AD16X units are stupid cheap.
Old 09-26-2021, 07:04 PM
Progear Progear is offline
Just got carbon 2 weeks ago, been using it with ferrofish pulse16 to connect to external gear, works perfectly..
Old 02-08-2023, 11:42 PM
scremedy scremedy is offline
ProGear - I'm looking for the same solution. Would like to get 16 channels of 48K out of my Carbon into a 16ch i/o on FerroFish. What's confusing me is that the Carbon has 4 ADAT ports and the FerroFish has 8. You were able to get 16 I/O with 4 ports on your Ferrofish?
Thanks for clarifying for me.
Old 02-09-2023, 01:41 AM
Ferrofish supports 16 channels at 96KHz whereas the Carbon only supports 16 channels at 48KHz, or 8 channels a 96KHz. Hence the difference in the number of ports.
Dominic
MacBookPro M1Max 16" 10/32 64GB 2TB, Ventura 13.6.6, Pro Tools 2023.12.1, Carbon.
Old 02-09-2023, 07:15 AM
Thanks Dominic for the level set.
Pro Tools Carbon with Standard and HDX? atticmike Pro Tools | Carbon 12 12-03-2020 04:24 PM
Pro Tools | Carbon Avid Technical Alerts 0 11-12-2020 03:14 PM
Pro Tools | Carbon... Start Here! Avid Pro Tools | Carbon 0 11-12-2020 03:14 PM
