Old 11-09-2018, 01:52 PM
jdleyden jdleyden is offline
Default Peripheral Loopback Test Connector Fail (HD Native PCIe)
Hoping someone can help me out, I've been pulling my hair out trying to fix this.
Basically every time I run the test with my blue 192s attached I get a failure.
This also causes Pro Tools to absolutely lose its mind and skyrocket my CPU usage to 100% all the time.
Weird part is, it doesn't happen immediately. I'll load a session and be fine for 5min and then the CPU maxes out. Same thing with DigiTest, I'll have no problem passing, and then suddenly I just start failing. I never fail when I scan just the card, only when I have a 192 attached. I've tried both 192s separately and in different configurations and on both ports of the HDN card.
Let me know if you need more info, hopefully someone has some more ideas!
Old 07-04-2019, 10:07 PM
brianjanthony's Avatar
brianjanthony brianjanthony is offline
Default Re: Peripheral Loopback Test Connector Fail (HD Native PCIe)
Did you ever solve this?
Brian
www.brianjanthony.com
MacPro 6 core 3.46 Cheese Grater
HDX and HD NATIVE
48 gig Ram
PT 2019. Something
Sierra
192 IO and 96 IO
TDM user way back. PT user since 98.
HDX Peripheral Loopback Test Connector Fail with AVID I/O Markk Pro Tools HDX & HD Native Systems (Mac) 3 06-07-2020 03:59 PM
Loopback Test Failed Incus Music macOS 0 02-23-2013 06:46 PM
Core Card Failure? Peripheral Digital Loopback Test FAILED digidesigner Pro Tools TDM Systems (Mac) 2 03-01-2011 04:28 PM
Digital Loopback Test Failure Krecording Pro Tools TDM Systems (Mac) 1 11-28-2007 08:07 AM
Distortion and Loopback test / X-HD interface Muzoid Pro Tools TDM Systems (Mac) 1 01-30-2007 09:16 AM
