Old 10-27-2004, 01:21 AM
sophiahat sophiahat is offline
Default Access Violation prevents song file from opening
I have a strange one that is got me scratching my head...
One particular song file that I try to open gives me a dialogue box " could not complete the"Open Session..." command because: access violation occurred".
It occurs at the very end of the loading process, and the task window is opened with a paused task of rendering a fade.
At this point PT is hung because I get the same access violation response if I try to close or do anything else.
Each time I try this procedure I notice a new fade file created in my fade files folder
I have been working on several files over the past few days and this is the only one that is doing this.
I installed Autotune 4 RTAS demo a few days ago, but it is working fine on other files, so I'm not convinced that is a problem.
I'm running PT LE 6.1 and Windows XP
Any help would be greatly appreciated.
SophiaHat
Old 10-27-2004, 01:40 AM
Default Re: Access Violation prevents song file from opening
Create a new session and import session data from the troublesome session a track at a time. YOu could also try deleting the DigiBase folder contents.
Rail
Platinum Samples
www.platinumsamples.com
Engineered Drums for BFD
Old 10-28-2004, 12:56 AM
Thanks Jon, that worked. It turns out that the culprit was a fade written on one of the tracks. Now, if I only knew how to prevent that from happening again.
thanks again
SophiaHat
Bounce - song down 1 key... access violation DennyLin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 05-27-2008 06:27 AM
access violation on opening application krysbaxter Pro Tools M-Powered (Win) 2 01-21-2008 01:16 PM
Access Violation when opening sessions PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-12-2007 02:31 PM
"Access violation occurred" when opening a session PLAbass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 10-06-2006 09:08 PM
Access Violation when opening and using video... Dazrae 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 08-18-2005 11:27 AM
