Old 05-18-2021, 05:39 AM
Noemie Noemie is offline
Default Tabs bug (Edit and mix windows)
Hi all,
as shown in the picture attached, the different windows tabs hide the upper part of the screen, and some of the controls.
Is there any way to hide these tabs ?
Any suggestion very welcome
https://www.dropbox.com/s/vxs9f1cbq0...22.14.png?dl=0
Old 05-18-2021, 05:48 AM
Default Re: Tabs bug (Edit and mix windows)
And I have to mention too that clicking on the tab's cross does NOT permit to close each tab, which indicates another bug.
AND I've juste noticed that I can't open the "Tempo change" dialog while PT is in fullscreen, it only opens while not in fullscreen mode.
There's definitely a big problem with the windows management.
Old 05-18-2021, 12:28 PM
cwsand's Avatar
cwsand cwsand is offline
From another thread:
Originally Posted by BScout View Post
System Preferences>Dock>"Prefer tabs when opening documents" setting
It's an Apple thing/problem
Help Us Help You
Chris
Pro Tools 2024.3
Focusrite LS56
Focusrite Pro40 (2)
TC Electronic Studio Konnekt 48
Avid Artist Mix/Control
Slate Digital VRS8
Analogue Tonebuss 24 Channel
UAD-2 OCTO Core Accelerator
UAD Volt 2
macOS 10.15.7
32 GB DDR4 RAM
NVIDIA GeForce GT 740 2 GB
Old 05-19-2021, 05:11 AM
Hi CwSand, and thanks for the advice.
Unfortunately this option doesn't exist in Big Sur.
BUT I've just find a way to manage this bug. The way is to not begin opening the edit window in fullscreen. I actually have to first open both edit and mix windows in non-fullscreen and then after set them fullscreen individually.
Then (command =) to navigate between the windows which are on two different spaces.
Can't say the problem is solved, but is manageable.
Have a nice day!
Open Mix & Edit as Tabs in single window (Mac) Rooxii Pro Tools 2019 26 04-15-2024 02:22 PM
Opening old session puts EDIT and MIX windows in separate TABS Eric Seaberg Pro Tools 2018 8 05-08-2020 09:39 AM
Guitar Tabs Becharax Eleven Rack 2 06-10-2013 06:21 AM
manually setting warp tabs/ deleteing multiple arp tabs glideman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 08-22-2010 01:31 PM
