Rewiring Reason 4 into Pro Tools
I found out how to plugin Reason, but for some reason everytime it loads up into pro tools it says "reason couldnt setup the control surfaces properly".... the midi controller is having an error because its already being used by another application (pro tools)...it's like when pro tools is open reason can't recognize my midi controller anymore...I create a new track as an instrument track and insert reason as the plugin; and when reason loads it no longer recognizes my controller because of pro tools interference with the midi port...does anyone have any suggestions? I want to use the sounds from reason and record them as tracks in pro tools. I'd appreciate any help thank you.
Re: Rewiring Reason 4 into Pro Tools
The ReWire slave is not supposed to setup the MIDI controller. All of that is handled by the ReWire host.
If you've ReWired properly, selection of the Reason instrumentation via PT will allow you to use your controller to "use the sounds" from Reason. |
http://duc.digidesign.com/showthread.php?t=277676 |
Re: Another Reason Rewire Issue: Rewiring Reason 4 into Pro Tools
Hello,
I'm not sure how to answer your question. I'm so clueless that I can't figure out how to start a new thread, so I'm sorry for jumping in here with a related question. I'm able to rewire Reason 4 into ProTools 7.4LE, and I'm able to load up stored Reason files. While in the session, all works well. My problem, though, lies in closing one session and opening another with a Reason rewire...or for that matter, closing down completely and starting back up a some point in the future. What happens is...the most recent Reason file loaded magically appears in all sessions with a Reason rewire. The only fix I've found is to remove the plug-in, save the session, close down ProTools, start back up, rewire Reason, load up the right file and go. But then, that file that I loaded up finds it's way to the session that I'd just fixed, before opening this there one. Now, this might be a minor issue, but when mixing a 16-track+ long album, forgive me, but it becomes just a bit more than annoying. Sorry again for jumping into this thread. If anyone can help, I'd appreciate it. Darryl |
All i had to do was turn off the "use with reason" option in the keyboard and control surfaces and prestooo. It had both rewiring at once so I had to turn it off in reason. Hope that helps.
Rewiring Reason 4 into Pro Tools | halifaxer12 | Pro Tools SE and Essential (Win) | 0 | 07-31-2010 09:25 PM |
Rewiring Reason 3.0 Into Pro Tools 6.8 M-Powered | bunderson | Pro Tools M-Powered (Win) | 2 | 09-26-2007 09:25 PM |
I'm fumbling with Rewiring Reason and Pro-tools | grinninsimian | MIDI | 1 | 10-10-2006 08:23 AM |
Rewiring Reason into Pro Tools! | zErOcOoL | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 12-03-2004 01:58 PM |
Rewiring Reason with Pro Tools LE | digdashdug | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 15 | 02-14-2004 04:37 PM |
