Monotoring
Hi all,
Any ideas on the best way to monotor the 001 I am using the mon out L and R into two chanells of my board, I like this as I can control the volume from my board, but when I make paning adjustments in pro tools this doesnt translate to what I am hearing . And when I trun the Left or chanell all the way down on My mixer I still hear the mix through both Speakers Please...where am I going wrong? Thanx NoteFarm |
Re: Monotoring
first I would go thru the main out 1/2 ...the mon outs is being controlled by the front which my not translate proper levels when metering...and make sure that you have ur board panned properely..and double check your I/O setup... I really can't tell you wants wrong since I can't see your setup but I am giving you some basic troubleshooting
DJ Jorge Felix [email protected] Midi Programmer/Remixer I make beats - Love that line |
Re: Monotoring
Check left to right cable consistency throughout your ENTIRE set up. When your done. Check it again! [img]images/icons/smile.gif[/img]
Also, like the above post suggests. Use the Main Outs of the 001. Not the monitor outs. dk
http://homepage.mac.com/dkrausz |
Re: Monotoring
Thank you for the great advice. That gives me some things I had not thought of, and a place to start,
Thanx again NoteFarm |
Pro tools 9 HD & Firepod Monotoring audio Not working | mincho1976 | macOS | 3 | 03-09-2013 12:38 AM |
