Re: To Big Sur
I found quite a bit of apps with a slash through them. Maybe I was mistaken, and saved a High Sierra drive . It's been a while, so I don't quite remember, and only miss those apps(like Peak) on occasion.
Anyhow, I did test the video with a fairly large project, streaming from Dropbox over the ethernet. Everything seems to be running fine. Now, I will update my Trashcan. If anything goes wrong, I can use my MBP for now. Maybe it won't take long for Avid to qualify this new update.
Music is the Message |
Re: To Big Sur
Avid needs to support apple silicon fast, because only then 3rd party plugins start to drop in. Remember the PPC/Intel transition? Took three years to be 100% done
Re: To Big Sur
JFreak, thanks for reminding me. I remember now. I went directly from High Sierra to Mojave. I skipped Catalina. I had so much trouble installing Cat, that Gave up and skipped it altogether. Thanks for pointing that out.
You're right about M1. I don't think that I will be ditching this i9 anytime soon, but with Apple, you never know. One thing for sure, now that I can't upgrade the machines myself...... It's heck of an expensive purchase
Re: To Big Sur
Composer/Sound Designer/Protools 2024.3 Ultimate, MTRXII-TB3, DADMAN MOM, Cisco SG350-10MP EthernetHUB, KLANG:quelle 4 Channel Dante™Headphone Amp, DVS,MADI, Mac Studio Ultra,128 RAM/4TB SSD, Ventura 13.6.5, DP 11.3, Logic Pro X 10.8.1 DOLBY ATMOS Facility/MPSE Motion Picture Sound Editors Avid Certified Professional ProTools/Dolby ATMOS |
Re: To Big Sur
I say NO to Bug Sir!
Thank God I have have made a SuperDuper! image before I upgraded to Bug Sir. It had turned my ProTools dream machine (at least for me, 2018 macmini with eGPU and RME UFX+ firewire interface) into a SLUGGISH monster. I have gotten into the habbit of upgrading my studio machine in August just before the next iteration of macOS drops to be sure I run into less problems with drivers and incompatible software. Usually I need to install a couple of new fixes and upgrades from developers and usually I'm pretty much fine. (with the occasional planned obsolescence where I need to buy new stuff) Now this year was different: 1. Both printers refused to work and both stole hours of digging through forum posts to get them back to work. Okay, we all know printer manufacturers will go straight to hell whenthey die, so that did not come as a shock. In the end I got it to work, but the kind of stuff I had to do in the terminal reminded me why I left Windows....Why Apple, why? 2. SLUGGISHNESS. My setup used to be a killer. I mean I could fire away key commands and it would react at hyper speed. In Big, Sur I can handdraw the waveforms (everything loaded into 40 Gigs of RAM allocated to PT with an eGPU to support the mac) and I would be faster than this crawler... 3. PT errors. PT tells me I am running out of CPU power. I have maybe 10 plugs on 8 tracks of audio no VIs. It is RIDICULOUS! (These sessions would take about 10% of CPU under Catalina. The same machine has been the center of my setup for Amazon originals mixes with a couple of added tracks and plugs....) 4. PT even crashes to the desktop during simple audio suite renders. Okay, I have had enough. Back to Catalina. This OS is a nightmare for me.
SOUND! |
#16
Re: To Big Sur
Big Sur is not actually REQUIRED for anything else than Apple Silicon, so it is safest to keep using Catalina for the time being. With that said my testing of fully loaded M1 Mac Mini has been surprisingly smooth sail. If I was using Intel hardwa re I would be staying on Catalina though, but on this hardware I have no choice. Whatever OS you use clean install is the key to less trouble.
#17
Re: To Big Sur
#18
Re: To Big Sur
The usual; running old sessions seeing which plugs are left behind, creating new dummy sessions for a stress test recording silence.. nothing serious in a real session with anyone else seeing the problems.. so far promising on the algorithmic plugin side of things, but 16GB memory gets obviously eaten fast when you start using VI's. But on the processor side it seems this Apple Silicon is distributing the load to different cores much much more evenly than Intel.
#19
To Big Sur
Was about to ask advice on this… I’m running Mojave 10.14.6 and PT 2020.12.1 on a 2019 MBP i7 6-core. Rock solid. BUT, with Apple support for Mojave about to end, I’d like to upgrade to a supported OS. That would mean Catalina (for one more year) or Big Sur. You say Catalina for Intel, eh? So, 10.15.7 and 2021.7 I assume? I won’t be going M1 anytime soon.
One good thing about music: when it hits, you feel no pain. --Bob Marley Rig: MacBook Pro (15,1) 6-Core i7 2.6GHz / 32GB RAM / OS 13.5.2 / PT 2023.9 / Waves Horizon v14 / iZotope Music Production Suite 4.1 / Focusrite Clarett 4pre USB / Apple SSD AP1024M 1 TB (System), Samsung T5 SSD 1 TB (Audio) / Cal-Digit TS3 Plus TB3 Dock / Genelec 1030A Monitors |
#20
Re: To Big Sur
I am running a completely unsupported configuration of a 2010 MacPro 5,1 on Big Sur 11.6. Pro Tools 2021.7. It has been rock solid on very large mixes with and without reference videos. The new video engine is better than it’s been in many versions. Probably the smoothest this machine has ever run. No issues at all.
But I run a very clean system and only use this machine for Pro Tools,
offthewallproductions Mac Pro 5,1 3.46 Ghz 12 core, Open Core 0.9.8, Radeon RX580 GPU, GC-TITAN RIDGE TB3 PCIe card, M.2 NVMe SSD boot drive on PCIe card, 48GB RAM, macOS 12.7.4 Pro Tools Ultimate 2024.3/HD Driver 2023.3 HDX, UA Octo PCIe card in external TB3 chassis, MTRX Studio I/O, C|24 control surface. Genelec 1031AP/7070A 5.1 monitoring. |
