How to Midi Learn a track's pan?
In PT, how to Midi Learn an audio track's pan parameter so we can control that pan from midi controllers.
Re: How to Midi Learn a track's pan?
as far as i have be able to find over the years is that you cannot map the Pan control. sorry man ... maybe someone else has a better answer for you
cheers john
Early versions of PT allowed mapping MIDI to pan and faders. But it went out at some point. I think I remember it being in 3.1. It wasn't as useful as you might expect because of the low resolution inherent to MIDI CC. 0-127 just doesn't cut it when the parameter you're trying to control has 201 steps (pan) or more (fader). It's too crude. It's a shame the designers of the MIDI spec didn't allow for a variable number of bits of res per CC. Even 10 bits is sufficient for faders. But it's water under the bridge now.
There are some nice little hardware and software controllers that work the pans and faders in PT. If you happen to have an iDevice of some sort, V-Control is the cheapest option. I'm also quite fond of my Faderport, which isn't all that much more money.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
MIDI Track's I/O Can't Output To Plugins | EvilCheese | Windows | 2 | 02-25-2012 07:13 PM |
No Midi Learn in PT7? Now what? | Chesney Digital Studio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 05-18-2011 11:07 AM |
Multiple MIDI Tracks controlling one Instrument Track's MIDI | daniel.yengle | Tips & Tricks | 3 | 05-04-2011 03:27 AM |
How to assign MIDI CC to plugin parameters if no MIDI Learn? | Mitch Manger | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-25-2007 11:10 AM |
how to assign a midi controler to an audio track's volume? | charlesB | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 05-16-2002 02:21 AM |
