The Command+Spacebar doesn't record
When I hit the "Command" and "Spacebar" keys to initiate recording, it doesn't work. I have already disabled the spotlight command in system preferences.
Does any one have an idea on this? I'm running a MacBook Pro, 2.16 Ghz processor, 2GB of Ram, 10.6.4 OS Pro Tools 8.0.4 cs2. And Merry Christmas |
Re: The Command+Spacebar doesn't record
Does the record button in the transport controls flash, when you hit command+space, or is nothing happening at all?
iMac Pro - MacOS 10.14.6 --- - Pro Tools U HDN 2019.6 - Avid HD Omni + HD I/O 8x8x8 - C|24 | S3 | Dock |
Yes, I've armed the tracks. The even funnier thing I forgot to mention is that I turned off "Dashboard" so when I use the F12 button or the number "3" key on the "number keypad" record works perfectly.
Nothing happens at all when I hit the command+spacebar combination. |
I also have the same problem, the Pro Tools 101 book mentions the Command-Space Bar shortcut (record straight away without going to record ready mode first). F12 and numeric keypad 3 seem to work fine.
Did anyone solve this issue?
Pro Tools 11.3.0 Mac Mini Focusrite Saffire |
is Spot Light still enabled? it is the same short cut command and supersedes Pro Tools command
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
I had the same issue, but the solution was to disable spotlight and then restart. The restart part took me the longest to figure out. |
In Mac:
1) Click the apple 2) Then System Prefs 3) Click Spotlight 4) Turn it off or change to key that's not being used by pro tools. Its here on this link.. http://avid.force.com/pkb/articles/e...oting/en337263 Hope this helps. |
Thank you!
My command + Spacebar is not working to record | Thejoe67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 02-20-2009 12:00 PM |
My command + spacebar isn't recording | Thejoe67 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 02-20-2009 12:49 AM |
Shift+Spacebar=play 1/2 speed..HOW TO Record that? | gollywillickers | Pro Tools TDM Systems (Mac) | 12 | 12-07-2005 10:42 AM |
Spotlight/record shortcut of apple/spacebar | nz | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 10-26-2005 12:50 AM |
Control + SpaceBar = Record?? | Raw-Tracks | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 9 | 10-08-2005 11:55 AM |
