Old 11-18-2010, 02:00 PM
funkntech funkntech is offline
Default 002 slave to SMPTE from Analog Tape
I want to stripe a track of my 1/2" Tascam 80-8 & have PT (002) chase - Can 9 do this now? I have chased using MTC (not true sync) and this eventually drifts especially if your tape's transport is not stable...Does the DV Toolkit have any benefits in this realm? Thanks
http://duc.digidesign.com/images/misc/progress.gif http://duc.digidesign.com/images/buttons/edit.gif
Old 11-18-2010, 02:32 PM
daeron80 daeron80 is offline
Default Re: 002 slave to SMPTE from Analog Tape
AFAIK, the answer is no. Sync-to-tape ability is something that has to be built into hardware. It's not something that can be solved via software alone. HD gear has the built-in ability to read the output of SYNC hardware. I know of no other AVID interfaces that have that.
David J. Finnamore
PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max
PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB
Old 11-18-2010, 02:37 PM
Craig F Craig F is offline
9 should be able to do it w/ something like a MOTO DTP
Thank you,
Craig
Old 11-18-2010, 02:55 PM
TOM@METRO's Avatar
I sync-to-tape constantly with SMPTE and a 002. SMPTE from tape to a MOTU MTP and then work clock to the OO2 via an EchoAudio interface. The 002 then follows word clock just fine.
~ tom thomas
Formerly hobotom
HD Omni and 192 I/Os
Windows 10
Intel Hexcore i7
All Samsung Pro SSDs
Ampex MM1200 2" 24 trk tape
www.metrostudios.com
Old 11-18-2010, 03:29 PM
Thanks All - Tom, can you please elaborate on the routing of the 3 units? Are you going Optical from the EchoAudio? The MOTU is spitting MTC from the Smpte? Do the MOTU & Echo interface? Thanks!!
Old 11-18-2010, 06:19 PM
New Hope Media New Hope Media is offline
The JL Cooper PPS2 will slave ProTools to incoming analogue timecode by converting it to MIDI timecode. You don't get external machine control in ProTools but you can certainly make ProTools chase the incoming MIDI timecode.
I've used it to stripe back to Digibeta from ProTools LE.
Have a look at the hardware here http://www.jlcooper.com/pages/pps2.html
Old 11-18-2010, 06:52 PM
cananball cananball is offline
I use a MOTU Digital Timepiece. Very versatile for all types of sync.
http://cgi.ebay.com/MOTU-Digital-Tim...item1e5fbb2269
Tape is LTC master sends LTC to DTP. DTP sends MTC to PTLE. PTLE chases incoming MTC. With 002 DTP can send clock via SPDIF.
Half he price of the JL Cooper piece and gives you more options, specifically word clock ( both word and spdif) and video reference for post with everything sample accurate locked
If you get one, after making al the connections, run it on SMPTE (LTC) mode and make sure PTLE transport is online and its MTC and synchronization is setup correctly.
Ken Wilkinson
http://kenwilkinson.tv
Pro Tools 10.3.9 HDN | HD Omni | Digi Command 8 | Artist Transport | Digi Surround Panner | Blackmagic Intensity Pro | JBL LSR4328 5.1
2.26GHz 8 Core Nehelam 8GB Ram OSX 10.8.5
Old 05-31-2021, 09:11 AM
EARTHAIRFIREWATER EARTHAIRFIREWATER is offline
hi cananball, i know very little about sync and time codes, and i'm trying to do the same thing that the original post refers to. i'm using a jlcooper pps-2 synchronizer and a tascam tsr-8 going into pro tools standard os9.0.6 with mbox pro. i stripe the tape with smpte, it goes into the pps-2 which converts smpte to mtc and then sends it to mbox pro and pro tools. the tape machine triggers pt to start and stop but they drift apart. they are not locking together. is this because pro tools needs mtc AND s/pdif word clock, like you said digital time piece can generate? thanks
Old 05-31-2021, 03:40 PM
This may be tough as you are trying to dredge up an 11 year old thread. Is there some reason you can't just record the tape machine's output into Pro Tools? If its 8 tracks, that should be fine. If its 16 tracks, grab a used Behringer ADA8200(I just bought one for less than $200) and connect via lightpipe. If its 24, I can see that would be an issue(in which case, I would find a studio with a bigger Pro Tools rig and have them do a transfer).
Old 06-01-2021, 06:47 AM
what i’m trying to do is to dump the fundamental tracks from some songs that i have in pro tools on to tape, to warm them up, and run them back into the songs/sessions that they came from (replacing the original tracks; there are also other tracks in the songs), and i also want to record some clean electric guitar for the same songs on to tape, and then run those recordings into pro tools, so i need both pt and the tsr-8 to stay in sync. it’s just a two head machine so i can’t get live tape warmth. I once owned an otari-8 which had 3 heads..… i should have kept it.
[IMG] code is Off
PT9 Slave to SMPTE funkntech 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 11-18-2010 11:49 AM
Slave HD to SMPTE fab Pro Tools TDM Systems (Mac) 1 02-17-2003 08:56 AM
SMPTE Slave Driver - Can I use one?? derF Pro Tools TDM Systems (Mac) 1 09-02-2002 05:53 AM
SMPTE Slave Driver ianstonehouse Digidesign Hardware & Software 1 05-28-2002 11:19 AM
SMPTE Slave Diver Brimmy Pro Tools TDM Systems (Mac) 3 03-28-2002 11:54 PM
