Old 02-24-2010, 10:51 AM
Nathan W. Nathan W. is offline
Default Loop Playback Not Working
Trying to loop a piece of audio and it's not looping, can't figure out why even though playback loop is enabled? PT 8.0.3 HD here...
Old 02-24-2010, 10:53 AM
backinthelab backinthelab is offline
Default Re: Loop Playback Not Working
Do you have quickpunch recording enabled?
If so, try turning this off and see if that sorts it.
Old 02-24-2010, 11:07 AM
GS-DK GS-DK is offline
+1.....I had the "problem" yesterday"
Old 02-25-2010, 09:03 PM
formfunction formfunction is offline
Are any of your tracks record armed? this cancels loop playback. ff
Old 02-26-2010, 10:21 AM
That did it. Did not know that record arming would cancel loop playback, that's a confusing feature. They should just not allow you to go into loop playback mode when you're arming tracks. Don't understand the logic of this...could someone please explain? lol
Old 02-26-2010, 10:27 AM
Actually I've got a track record enabled in my session with playback loop working? This is weird, not understanding when it works and when it doesn't work. I DO notice that certain highlighted lengths (particularly small sections) of audio will not playback loop. Haven't looked in the manual but I'm guessing there's a minimum playback highlighted loop length, like you can't loop anything under a half a second or something.
Old 02-26-2010, 10:31 AM
Just did a test, you can loop playback 15 frames maximum, maximum is half of a second you can loop playback.
Old 02-26-2010, 10:35 AM
Drew Mazurek's Avatar
It depends on whether Quickpunch is on or not, not if a track is armed or not.
Search the pdf manual for Quickpunch.
www.drewmazurek.com
Old 02-26-2010, 10:36 AM
Sorry for the posts: Figured it out, it's TRACK PUNCH MODE, does NOT allow you to loop playback. THAT's confusing. When going into track punch mode they should disable loop playback mode in future versions of ProTools or at least provide some indicator so you know loop playback isn't broken. lol
Old 02-26-2010, 11:54 AM
Neither does Quickpunch.
TrackPunch is a special mode used by Film Dubbers and should IMO never even be turned on in the music session.
www.drewmazurek.com
Loop playback not working since my 9.0.3 update notrude55 macOS 9 02-24-2012 09:40 PM
Loop playback not working? IVcrane 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 05-25-2010 02:07 PM
Loop Record and Loop Playback will not engage? Angelo of Onello 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 02-28-2008 06:03 PM
About loop playback stevegalante Tips & Tricks 4 09-22-2000 12:57 AM
