Old 09-02-2021, 06:07 AM
rademusic's Avatar
rademusic rademusic is offline
Default Pro Tools First crashing with Eleven Lite
Hi there,
I’ve been using some of the plugins I’d downloaded as part of my Pro Tools First M-Audio Edition which have worked fine, but once I downloaded Eleven Lite, PT kept freezing at the ‘scanning plugins’ bar upon launch. When I moved Eleven Lite out of the plug-ins folder, PT worked as normal again.
Update 10/1/2021: The above also happens with InTune in my plug-ins folder also.
I’ve tried:
- Optimising my Mac for Pro Tools as suggested here: https://avid.secure.force.com/pkb/ar...em_Preferences (except turn off Wifi because it needs it)
- Deleting the Pro Tools preferences folder and emptying the trash
- Uninstalling and reinstalling Pro Tools First
- Uninstalling and reinstalling Avid Link
- Uninstalling and reinstalling Avid Cloud Client Services
Since doing these, PT still freezes at startup with Eleven Lite in the plug-ins folder.
I read on the Pro Tools | First 2021.6 Read Me that “Purchased plug-ins are not loaded again if they are ever manually removed from the plug-ins folder (PT-202619)… Do not remove purchased plug-ins from the Plug-ins folder."
I haven’t moved Eleven Lite from the plug-ins folder since reinstalling. I've also checked out this thread https://duc.avid.com/showthread.php?...highlight=plug though I don't think you have to register the free Avid plugins with iLok License Manager? I didn't have to for the other plug-ins I downloaded that work.
I’m not sure what else I can do now so I’d appreciate your help!
Technical information:
MacBook Air (M1, 2020) 8GB RAM Big Sur 11.4
Pro Tools First version: 2021.6.0
Interface: M-Audio Fast Track USB - I know it doesn’t say it’s compatible but it still works and records in PT First just fine. Through a USB-C hub. Though the issue still occurs with neither the hub nor the interface connected.
M-Audio BX3 studio monitors
Thanks,
Seth
Old 10-01-2021, 01:28 AM
rademusic's Avatar
Default Re: Pro Tools First crashing with Eleven Lite
Just an update, now the same problem occurs with InTune in my plug-ins folder also. Can anyone please help?
rademusic.bandcamp.com
MacBook Air M1 2020 8GB RAM Big Sur 11.4
Pro Tools | First 2021.6.0
M-Audio BX3 Studio Monitors
Eleven Lite plugin clean only. IGUNNZI AAX Plug-ins 7 02-28-2023 05:49 AM
Eleven lite PTF Gear Getting Started 4 10-07-2021 02:26 PM
Eleven Lite noise Buzz Moschetti Virtual Instruments 5 03-21-2020 12:05 PM
Eleven Lite dry/wet mix Buzz Moschetti Virtual Instruments 2 02-10-2020 04:02 PM
Eleven Rack with Ableton Live Lite 7 Made2PraiseHim Eleven Rack 8 08-25-2013 05:15 AM
