Re: Can someone advise me on a brand new HDX setup?
To correct delay on an input track (which only applies when delay comp is on), in the mix window, adjust the user offset delay. (in samples or milliseconds depending on what is selected in Preferences) But a reminder, by default, when a track is input enabled or in record, delay compensation is disabled for that track until it is out of input enabled/record. You can put it in "blue mode" (Auto Low Latency off) to keep delay compensation active when in input enabled/record. (but of course, that means you will be hearing latency during recording) (Also, a note from personal use: I usually just have the nudge value written and adjust after a pass vs using user offsets. User offsets fix the audio output but the clip/waveform will always look in the wrong place. Nudging fixes that. Otherwise you can end up in a situation where you are trying to align audio on two different tracks but it sounds off due to the user offset still being applied to one of those tracks)
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Also, would not recommend Antelope. Terrible company. Terrible support and terrible software (that stupid launcher that is there only for advertising/pushing Antelope goods, having to "activate" hardware to get it to work when you get it new otherwise it does nothing, and terrible long-term support.)
18 months is not a case study on a company. Come back after 3 years of use. (That is if Antelope hasn't already decided to ignore your product for support since they have "new" versions to sell)
I think what you really need to be asking are questions like "will I be happy constantly juggling native and DSP resources in the hybrid engine?" and "will latency akin to a native DAW running 64 sample buffers be suitable?" because that is really what you will be walking into with HDX1. A single HDX card doesn't have enough DSP to track 64 live inputs with 8 sends per channel (4x reverb, 4x cue). That is before you even add a single AAX-DSP plugin. Almost every third-party AAX-DSP plugin also has a minimum of 33 samples of latency too, so you will be running a real world RTL well beyond a modern native DAW at 32 sample buffers. HDX was an amazing platform when it was first released, but a decade later it is a long way from being a magic bullet. You need to be realistic about what it will actually bring to the party, which in 2023 where stuff like dual native sample buffers are common place, is a lot less than many people are aware of. The hybrid engine was a real revelation here. It makes for some very easy comparisons between HDX + Native and Native only sessions, and I found HDX was only really conserving about ~8% CPU on my 10-core iMac Pro. For that ~8% savings, a HDX card costs a pretty penny and brings some considerable workflow related baggage with it that a native system avoids entirely. If it were I, I would be spending the a few extra hundred bucks on a 13900K over the 13700, rather than tossing thousands at a HDX card.
Pro Tools Ultimate 2024.3. OSX 13.6.5. Win 10. HD Native. Lynx AES16e. Lynx Aurora 16. i9-13900KF. ASRock Z690 Steel Legend. 64GB Ram. AMD Vega 64. BM Decklink. Dolby Atmos Renderer 5.2. Trinnov D-Mon. D-Command. |
New ProTools setup little advise needed | tijn1311 | macOS | 4 | 12-01-2014 02:02 PM |
Moving to Europe...need help with brand new setup | manilarice | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-19-2010 10:02 PM |
brand new mac user.... please advise | dusty | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-29-2006 06:12 AM |
2 studio' s 2 different macs - need setup advise | freakuincy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 11-16-2001 08:25 AM |
Brand New To PT..Need MIDI Setup Help! | Hardnox | MIDI | 2 | 07-07-2001 11:48 AM |
