Long time issue finding audio files from timeline on disk
Well, basically we talk about 2 issues here, one general and one in particular I really need to be solved:
1st) In general, that the functionality to find used audio files per click seemed to be broken nor really supported in Pro Tools PC since various versions, like many reported already coming from other DAWs where this is a mouse click to open the file in an external editor or find it on disk. To use "find in explorer" or "find in Workspace (soundbase)" yealds often to no results. Nor does it open any explorer window etc. and 2nd.) becoming even more problematic when you get an import from film edit for sound mix & sound design, and you need to restorate some clips in the timeline, without being able to find them easely in Pro Tools. Even by trying manually. Since the names of the clips are often cryptic and relative to the imported cuts, their IDs and can not be found in the project nor in the AAF media from import by that names in the clip window. Even the mouse over names do not help because they only reflect the original name of the used file in film edit but not the "clip" we need to find. How do you guys find a "5eg7h345hjk377asd54eeff095.wav.original-name.L.whatever" named clip on disk which is the REAL representation of what is USED in the timeline on an AAF import from an film edit session export which uses the cuts as individually seperated files with tails (not the original media)? I am able to manually distinguish and find the ORIGINAL media because of the client who gave us the original files for just in case. But this is NOT the cutted clip with its tails used in the imported session. Since we know that Pro Tools claims to be somewhat the industry standard for that kind of jobs, I really wonder how frustrated studios must be in such a case. What are we overlooking or do we are missing here? Or is it simply a long-term bug never been fixed?
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... Last edited by dgdsu; 10-06-2022 at 08:06 AM. |
Re: Long time issue finding audio files from timeline on disk
On some clips "Reveal in Explorer" is even greyed out by the way and the "Reveal in Workspace" just opens another Soundbase window. But it does not hint to the file and just shows a general overview of the Locations left with an empty list to the right.
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... |
That seems like one of Premiere's auto-generated names. With those AAFs you often need to tell PT to relink by Name Only. Deselect everything else. Then it should find them. This is upon importing the AAF correct?
As far as finding the files in Explorer that depends if you linked or copied on import.
~Will |
@smurfyou Thanks for helping here on this! Very very much appreciated. Will try your solution. So you think this is rather a rare case that the contextual options of "Reveal in ..." do not work here? From what I remember is that it even did not worked on simple record sessions even some weeks ago. But who knows if I mix things up here now. EDIT: and yes you are right, it's a Premiere import. The reason why I remember that so well is that I was like "Oh no... Premiere". Not a big fan of it TBH. Quote:
Well, this session is a project reboot so it is more than half a year ago that we imported it, but I remember that one way was preferred over the other because of issues ... But since the files admit to be linked to the original import folder I assume they are just linked not copied. Otherwise they would be in the project folder I think. But even these links seem not to work for the Reveal function. Wierd ...
Windows 10 Pro x64 - Intel Xeon CPU E5-2630 v4 @ 2.20GHz, 2201 Mhz, 10/20 Core(s) - 64 GB Ram - ASUS Mainboard X99-E WS/USB 3.1 (LGA 2011-v3) - Most hard drives SSD - AVID Pro Tools (Native) - AVID Media Composer Ultimate - AVID Eucon artist series - RME UFX audio interface with integrated Midi interface - ADAM Audio - HEDD audio - Brauner - Klark - Scheps - Neumann - Furmann - Sennheiser ... Last edited by dgdsu; 10-06-2022 at 12:45 PM. |
If a clip cannot be revealed in explorer, it might be a virtual clip referring to a part of another file with another name. As you mention finding "original", I can separate clips as I wish, have hundreds of clips, and only one file.
If you have a clip on the timeline, and you consolidate it, then you can double click it and rename "clip name and filename" (or whatever it says). If you double click on a clip and it doesn't allow you to change the filename too, that's 100% explained just there regarding whole file vs edited non-consolidated clips. It doesn't let you if the clip is not consolidated as far as I have experienced.
___ >> me: nednednerB // ||main gig: editing audio voiceovers & testing software | 2nd gig: music software tutoring | hobby: electronic music // ||software: Sonoma 14.2 | PT Studio 2023.12 | Ableton Live 11 | iZotope RX, Ozone, Neutron | Arturia Pigments | Auto-Tune | Dubler2 // ||system: iMac (Retina 5K, 27", 2020) 10-Core-i9 | 128GB-DDR4 | 5700-XT-16GB | OWC Thunderbolt Hub and Thunderbolt 3 Dock // ||devices: RME Babyface Pro FS | Focusrite Clarett 2Pre | some AT mics | SM58 | Ableton Push 2 | Sennheiser HD 600 HP // Onkyo TX-8220 SR ||automation: SoundFlow | Stream Deck+ | Keyboard Maestro | SteerMouse | MacOS Shortcuts // |
Calibration issue (long time user) | ChrisSnyder | Pro Tools TDM Systems (Mac) | 3 | 06-20-2013 02:56 PM |
Finding audio files manually... | Floydio | Post - Surround - Video | 6 | 10-08-2011 06:01 AM |
Files taking a LONG time to open | jameshbotha | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 04-30-2010 08:51 PM |
Elastic-Time on long stereo files with PT 7.4? | A1 | Pro Tools TDM Systems (Mac) | 6 | 02-19-2008 11:52 PM |
Shorten project time?Bounce files 2 Long... | ircswh | Pro Tools M-Powered (Win) | 3 | 01-15-2007 07:54 PM |
